Old April 25th, 2015, 09:42   #1
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Default Unofficial MK7 Oil Change Guide
Start by securing car on jack stands or ramps and remove the belly pan.
8-T25 Torx
3-T45 Torx
Remove the drain plug using 19mm socket or wrench.
Remove t27 Torx and set aside the coolant heater if equiped (usually Canadian models)
Unplug the after run coolant pump,pulling the gray tab backwards in the direction of the wires and pull straight out.
Remove oil filter canister cap using 32 mm or a 1 1/4 sockets works too but it's tight.
Replace the cap O ring with new one with filter and place the filter in first then the cap it's easier that way I tried both.
Put the oil drain plug back in and torque to spec,can't recall.
Top up with 5.5L of your choice of 504/507 VW approved oil.
Start the engine and check oil level on flat ground.
Reset reminders to next service.
Works for both Golf And Jetta.
https://youtu.be/Z_IQsoBARms
Tools needed;
T25
T27
T45
1/2" breaker bar 18" or Rachet
32 mm or 1 1/4 " socket with extension.
19 mm open end wrench.
Overall this took about 1 hour and not to bad at all. Not as easy as MK4, 5,6 but it's not difficult at all.
Good luck !
About 5L came out so I'm assuming consumption is about .5L per 16,000 km
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old April 25th, 2015, 10:17   #2
badufay
Thanks buddy! I am going to knock this out soon too!
Current: 2017 GTI S, 6 spd man; 2017 Jetta SE TSI, 5 spd man
Previous: 2015 Golf S TDI, 6 spd man; 2015 Jetta SE TDI, 6 spd man; 12 Jetta 2.5L, 04 Jetta 2.0L, 02 Golf 2.0L, 98 Jetta 2.0L, 98 Golf 2.0L, 98 Cabrio 2.0L, 95 Golf 2.0L, 87 golf GTI 16 valve 1.8L, 86 Cabriolet 1.6L, 80 Audi 4000 1.6L, 76 Audi Fox 1.6L, 76 VW Beetle 1.6L, 74 Audi Fox 1.5L, 69 VW Beetle 1.5L
badufay is offline   Reply With Quote
Old April 25th, 2015, 15:59   #3
Nutty 5.0
Nutty 5.0's Avatar
Excellent and thanks Jason! I pulled my cover off underneath when I got the car home and saw its really not as bad as it looks. And an hour isn't bad at all.
15 GSW SEL 6MT Malone Stage 2. Six Sigma Shifter, 034 mount insert, Neuspeed torsion bar. I have lifts in my home garage, VCDS, and do side work. PM for details.
Nutty 5.0 is offline   Reply With Quote
Old April 26th, 2015, 10:00   #4
copperbeech
Thanks very much for doing this Jason.
copperbeech is offline   Reply With Quote
Old April 26th, 2015, 14:36   #5
drew1202
great post and pics Jason. 1 hr isn't bad at all. How messy was the removal of the filter?
drew1202 is offline   Reply With Quote
Old April 26th, 2015, 15:34   #6
Matt927
Matt927's Avatar
TDI(s): several
Thanks for the pics/post
Matt927 is offline   Reply With Quote
Old April 26th, 2015, 19:56   #7
2002_tdinut
Awesome job Jason. Thank you so much for your efforts.
2002_tdinut is offline   Reply With Quote
Old April 27th, 2015, 12:12   #8
nectarguru
Great thread! So can you not use an oil extractor on the Mk7?
nectarguru is offline   Reply With Quote
Old April 27th, 2015, 15:04   #9
Matt927
Matt927's Avatar
TDI(s): several
Sure you can but you have to pull the lower paneling to access the oil filter anyway.
Old April 27th, 2015, 15:05   #10
2002_tdinut
Looks like you still have to get under the vehicle to get at the filter. It would make sense that once you are down there, open the drain valve.
Old April 27th, 2015, 18:34   #11
Verbosity1
Thanks for posting this, recently purchased a 2015 golf TDI, and post break-in will need to change the break-in oil. Much appreciated!
Verbosity1 is offline   Reply With Quote
Old April 28th, 2015, 03:54   #12
Matt927
Matt927's Avatar
TDI(s): several
Your first oil change is provided free of charge by the dealer at 10,000 miles.
Old April 28th, 2015, 09:59   #13
obababoy
Fuel Economy: Avg over 8k miles 21.9 w/subaru
Going in tomorrow for our first oil change. 10,000 miles. Arent there a few software updates I should ask about?
obababoy is offline   Reply With Quote
Old April 28th, 2015, 11:40   #14
badufay
There is a radio one (Released Jan/Feb)... I just go it a few days ago...Just firmware to fix some minor issues I guess
Old April 29th, 2015, 07:09   #15
VW_TDi_
VW_TDi_'s Avatar
http://forums.tdiclub.com/showpost.p...67&postcount=1
2015 Golf TDi|DSG
2001 Jetta TDi
VW_TDi_ is offline   Reply With Quote
Margey's guide to fuel filter change outs LargeMarge VW MKV-A5 Golf/Jettas 24 January 18th, 2010 19:33
error in timing belt change guide zeaustar VW MKIV-A4 TDIs (VE and PD) 2 April 30th, 2009 13:15
Need TB change guide in Brighton, MI area. master cylinder VW MKIV-A4 TDIs (VE and PD) 6 May 9th, 2004 09:47
Page generated in 0.17829 seconds with 11 queries
[Output: 124.20 Kb. compressed to 103.17 Kb. by saving 21.03 Kb. (16.93%)]
