Go Back   TDIClub Forums > FAQs (Frequently Asked Questions) > TDI Power Enhancements
TDI Power Enhancements Archives on TDI Power Enhancement related items.
Old February 14th, 2000, 15:29   #61
HowardZ
Default Re: GARRETT VNT HOP UP PICS
My mechanic took a body panel off under the steering wheel and he tapped into the dash's dimmer switch. In this way the gauge's light dimms with the rest of the instrument cluster.
HowardZ is offline   Reply With Quote
Old March 20th, 2000, 07:19   #62
SkyPup
Guest
I just looked in the fuse directory right under the front A-pillar for the fuse running the headlamps and stuck the hot lead for the boost guage light into the fuse mount. I attached the ground to a bolt down below the dashboard. Boost guage lamp comes on and goes off with the headlamps the way it should!
Old March 20th, 2000, 18:52   #63
Michael NJ
When I put the boost gauge in my 2000 Jetta I just tapped into the light by the cigarette lighter. Take out the red tray, unscrew the one torx screw, and the assembly comes right out (slide forward and up). Tap into the orange wire and the grey wire and the boost gauge light will work with the dimmer.
Michael NJ is offline   Reply With Quote
Page generated in 0.15971 seconds with 10 queries
[Output: 52.38 Kb. compressed to 47.37 Kb. by saving 5.01 Kb. (9.57%)]
