Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old December 6th, 2014, 04:06   #16
dirtysouthjacket
dirtysouthjacket's Avatar
Thanks for the link! I'm adding it!
2012 Jetta TDI Premium; Dual Horn, Hybrid Grill, bunch of sound deadening to install
2004 Jetta TDI GLS - SOLD
1991 Mastercraft ProStar 190
2011 BMW F800GS, 2003 Kawasaki Super Sherpa, 1997 Kawasaki KDX200
dirtysouthjacket is offline   Reply With Quote
Old December 24th, 2014, 11:06   #17
torrimac
Here is a different take on DSG fluid change,
http://www.myturbodiesel.com/wiki/ds...nic-oil-flush/
Link to a place to buy the "tool"
http://mobilfaction.com/products.html
Link to the AST tool DSG adapter.
http://asttool.com/detail_page.php?t...252016%2520DSG
torrimac is offline   Reply With Quote
Old December 24th, 2014, 11:14   #18
torrimac
This is a link to info about the Electromechanical steering rack
https://drive.google.com/file/d/0B4U...ew?usp=sharing
Old January 6th, 2015, 04:43   #19
dirtysouthjacket
Ok thanks torrimac! I added them. I had not seen the Steering Self Study guide before.
Old January 12th, 2015, 12:26   #20
torrimac
I lifted this from the fluids & Lube forum, Mileage may vary, My local NAPA would only order the DSG fluid in a 12 liter case. And they said they could not find the Engine oil. I did not ask for prices.
Originally Posted by ZiggyTheHamster View Post
Forgive me if this is already mentioned or common knowledge, but NAPA now carries Lubro Moly and Pentosin.
Part numbers, you say?
Lubro Moly Top Tec 4200 (505.00/507.00) = LM3707
Pentosin FFL-2 (DSG fluid) = G 052 182 A2
The problem is that they don't have it in stock at most of them - usually only in much larger cities than Tulsa. But they can order it and have it in a couple weeks.
So if you have patience, you can now pick up 507.00 oil at NAPA, Pep Boys (Mobil 1 ESP), and the dealer. Always in stock at Pep Boys FWIW.
Old January 13th, 2015, 04:24   #21
dirtysouthjacket
Thanks! I am working on a "Where to Buy" but it's a slippery slope and I don't want to show favoritism to vendor's. Also the list would be long for certain items. I need to ask a mod for clarification.
But I did find the dealer to be the cheapest on getting oil and always in stock, surprisingly. But overpriced on filters. Pep Boys was a good bit more, but also had Mobil in stock. I found on my most recent oil change kit the trusted online vendor's to have the best total package price overall.
Old January 16th, 2015, 15:05   #22
torrimac
This was posted in another thread about filters. But it might be nice to have in here.
There are 2 styles of fuel filter's. Need to make sure you order the right filter if you are going to do your own filter change.
http://www.myturbodiesel.com/wiki/fu...d-audi-a3-tdi/
Old January 17th, 2015, 10:17   #23
dirtysouthjacket
Thanks, I've got that linked under maintenance for the filter change. I assumed people would catch that while doing research. But it is good to call it out separately since it is an easy mistake.
Old January 3rd, 2016, 08:40   #24
Stealth TDI
Pre-Forum Veteran Member
Stealth TDI's Avatar
Nice thread! I had no idea it existed. Just wanted to give it a thumbs-up!
| .M y . S t a g e . 2 . G T I . |
| Facebook | YouTube | Fuelly |
Stealth TDI is offline   Reply With Quote
Old March 4th, 2016, 05:56   #25
meerschm
meerschm's Avatar
http://pics.tdiclub.com/data/500/201...0k_Service.pdf
updated with the fuel filter change.
Mike
Free advice: it is worth what you pay for it. (sometimes)
meerschm is offline   Reply With Quote
Old March 11th, 2016, 18:34   #26
1001 lb-ft
1001 lb-ft's Avatar
TDI(s): 2013 JSW
I would like to extend my appreciation for the time you put into compiling this information. Extremely helpful.
1001 lb-ft is offline   Reply With Quote
Old March 15th, 2016, 13:29   #27
dirtysouthjacket
No problem!
Old November 24th, 2016, 07:28   #28
meerschm
meerschm's Avatar
Default software fix for P2463 and P2458 for 2015 MY
see: http://forums.tdiclub.com/showthread.php?t=469809
seems there is a TSB out that advises a software update is needed for the fault codes below
http://pics.tdiclub.com/data/500/2015_DPF_TSB.pdf
TSB above addresses DPF problems on 2015 TDIs which need a software update.
Fault Code Fault Description
P2463 Diesel Particulate Filter Soot Accumulation
P2458 Diesel Particulate Filter Regeneration Duration
Note:
DO NOT diagnose or replace components due to DPF faults before performing the update function as explained
in this bulletin.
Mike
Old April 26th, 2017, 18:27   #29
TonyJetta
Fuel Economy: A5: 36mpg Avg / A6: 39
Does anyone know if the oil change interval changed from 10K on the 2015 EA288?
TIA,
Tony
Diesel fleet: '15 Jetta TDI SE; '06 Jetta, TDI, DSG-5sp Conversion; '06 DC Cummins, CC/LB/DRW; Past Project car! Troubleshooting Links: Trusted TDI Mechanics IP Timing Timing Belt FAQ A3/B4 Low Power Cyl Head Repair Fault Codes What you have just read is an opinion...take it as you see fit!
TonyJetta is offline   Reply With Quote
Old April 27th, 2017, 15:28   #30
tomo366
TDI Lifer, Member #131
tomo366's Avatar
It is still 10K
My page is Dedicated to the Memory of
Christopher Farnham RIP my friend!
Great friend and supporter of TDICLUB
2015 Jetta TDI SEL Tornado red
2014 BMW 328D XDrive Glacier Silver
2004 Jeep Grand Cherokee Black!
tomo366 is offline   Reply With Quote
MkVI DIY/FAQ - Start here dzcad90 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 20 November 6th, 2019 16:39
MkV (05.5 - '10) Jetta FAQ/DIY kromicacid VW MKV-A5 Golf/Jettas 17 December 19th, 2017 10:43
FAQ: 2009 - 2010 TDI-specific issues DoctorDawg VW MKV-A5 Golf/Jettas 240 February 2nd, 2017 15:56
Mudflaps for Jetta MKVI Sedan BarrieCommuter VW MKVI-A6 Jetta Sedan (~ 2011+) 3 November 18th, 2010 15:30
'05.5-'06.5 Jetta FAQ/DIY eluwak VW MKV-A5 Golf/Jettas 33 October 14th, 2009 16:29
Page generated in 0.17234 seconds with 11 queries
[Output: 131.31 Kb. compressed to 109.47 Kb. by saving 21.84 Kb. (16.63%)]
