Old September 23rd, 2019, 06:24   #511
740GLE
thats a $1500 fix if holding the power button didn't work, scary thought
Old September 24th, 2019, 13:39   #512
BarryT82
I got my rattle sound fixed! There was a bolt missing on the fuel filter housing according the to service advisor. He said that three bolts hold it in place and it only had two.
BarryT82 is offline   Reply With Quote
Old November 20th, 2019, 13:10   #513
TDI_Ry
TDI(s): MK7 Golf TDI
So a few days a go I noticed a vibration while coasting at various speeds. The vibration would go away while under acceleration and no noticeable vibration or noise from any tires and nothing on the steering wheel. It sounds like the bottom belly pan cover was flapping away in the wind or that something is hitting it over and over again.
At first it seemed like it was coming from the front passenger side area. It has now moved to the front middle of the car and I could hear/feel it under the drivers side floor only when coasting. I first thought it was the plastic bottom engine cover that was loose (it wasn't this). I took the cover off and saw nothing noticeable that would be causing this problem. The only thing would be one of the hoses for emissions but it's been like that since I had the car with no such issues.
Only thought would be my winter tires which I recently put on a week ago (didn't have issues until several days later)
Any thoughts?
TDI_Ry is offline   Reply With Quote
Old November 20th, 2019, 13:13   #514
Switch the tires front to rear and see if the noise moves or goes away.
2002 Jetta wagon, 400K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 289K; '99.5 Golf, 260K; 2011 335d, 63K; 2015 Golf Sportwagen, 13K. Principal, http://www.idparts.com
Old November 20th, 2019, 13:29   #515
TDI_Ry
Was gonna give that a shot today.
I appreciate the feedback.
Edit: solved.
Buying a 2006 2.5l TDI (R5) - Looking for advice on common issues? rsd VW Touareg TDIs 2 June 23rd, 2014 15:37
CV Boot Issues Common? JBell VW MKVI-A6 Jetta Sedan (~ 2011+) 5 February 15th, 2014 02:26
Common issues at 250k miles bmccrea TDI 101 9 November 6th, 2009 13:22
Lag issues common arnd 90000? What 2 tll dealr? ChadMad VW MKIV-A4 TDIs (VE and PD) 1 May 5th, 2005 19:14
(Early) New Years resolutions for my B4 TDIMeister VW MKIII-A3/B4 TDIs 4 December 23rd, 2002 07:29
Page generated in 0.09689 seconds with 11 queries
[Output: 71.45 Kb. compressed to 63.46 Kb. by saving 7.99 Kb. (11.18%)]
