Old December 9th, 2014, 10:43   #31
Callipygian
Yesterday got out of work to find my CEL has come on...awesome! The manual says ease off throttle and make your way to a garage... great! Second trip to dealer in a month, only 1400mi.
The cel stayed on all last night, had to run errands and restarted the car 3 times throughout, stayed on.
This morning get up for work and cel is gone.
Will dealer be able to read what it was?
Callipygian is offline   Reply With Quote
Old December 9th, 2014, 10:46   #32
Callipygian
Originally Posted by FVWVWF View Post
Im thinking about getting a Golf....so I reading this I can assume ya'll not having any squeeking/cracking/popping interior noises like the 11-12 Jetta's?
Car drives soundly other than what sounds like a somewhat louder than expected fan whir/whistle coming from the a/c vents when climate control is on.
The only popping was my blood vessels when I saw the cel come on last night.
Old December 9th, 2014, 10:47   #33
Korab
Fuel Economy: it had better be good
Maybe. It depends on what it was. some reset, others leave a fault code. Always best to drive it straight to the garage and leave it idling until they can put put an OBD reader on it to pull the code.
Korab is offline   Reply With Quote
Old December 10th, 2014, 20:54   #34
Ben Carufel
In deference to what Korab said above; As I understand it, all OBDII cars will store a log of faults. If they've self-reset they will come up as "Not Currently Present" in the scan, but the code should still be stored.
Ben Carufel is offline   Reply With Quote
Old December 14th, 2014, 15:51   #35
andyrooski17
andyrooski17's Avatar
As posted in a different thread on this forum, I am the second to see what appears to be crystallized urea from a small leak, so I wanted to include it in this sticky thread.
This is apparently the DEF injector port, which is located adjacent to the north-west corner of the engine cover (when viewed standing in front of the car).
WiszMaster, who first noted this, had his DEF injector port and feed hose replaced around 12/5. He hasn't yet reported whether the problem is gone or not.
I'm not sure as to the severity of this problem, but I'll be calling my dealer tomorrow to see what they say and hopefully have it addressed. I will report back on my experience. I would encourage everyone else with a Mk7 to check their cars.
andyrooski17 is offline   Reply With Quote
Old December 15th, 2014, 14:51   #36
StormyTDi
Total newbie question, so please go easy on me... :-) I searched in the forums, but I was unable to locate any kind of basic list of things to check for before taking delivery on the MK7 TDI; I'm finally taking delivery of my TDI SEL this week, and want to be sure I look over any common issues and have them fixed before I drive off the lot. Below is what I've gathered from this thread...
- Dripping rear washer nozzle
- Fuel door mis-match on colors
- I’ve read somewhere to check that the doors align properly
- MDI cable for iPhone 6 should have a blue or green collar
- Hockey pucks used for shipping removed from springs
- This may not be apparent upon delivery, but keep an eye out for leaks on the DEF injector port
Any other suggestions, or items, of things to look for when I pick it up?
Thanks!!
StormyTDi is offline   Reply With Quote
Old December 15th, 2014, 15:25   #37
JASONP
JASONP's Avatar
Fuel Economy: 4.5l/100
Thanks!!
Other than the visual obvious , issues come up after you've put a few thousand miles on your new car.
Just go through all the controls inside the cabin and make sure they all work properly.
The dripping rear washer jet is a known issue and there is a TSB for it it the US anyways, fuel door mismatch that's one to take up with the dealer itself as they may or may not decide to repair that (I was promised a new one repainted but yet to see it)
crystalizing of the DEF you won't see right away during pickup
Sent from my SM-G900W8 using Tapatalk
2016 Jeep Wrangler, no longer do I have a diesel, repair manuals or spare parts sorry.
JASONP is offline   Reply With Quote
Old December 15th, 2014, 15:31   #38
TurnOne
I focus on paint and body. The rest can be fixed or lemon lawed.
Chris
TurnOne is offline   Reply With Quote
Old December 16th, 2014, 08:02   #39
StormyTDi
Excellent, thanks!! I'm stoked - first VW and first diesel! Just waiting on the dealer's call to find out when I can come in. You'd think after waiting over 3 months, I'd be used to waiting by now - but it's worse knowing it's local and not being able to get it. Ugh...
Old December 16th, 2014, 08:38   #40
JASONP
JASONP's Avatar
Merry Christmas
Old December 16th, 2014, 08:41   #41
kjclow
Fuel Economy: 55 max / 44 avg on beetle ~37 on JSW
Be prepared for the new door not being an exact match either. The fuel door is plastic and takes paint differently than the metal body panels. largest issue is still the metallics, which is why the silver looks the worst. You are also now working with a different batch of paint that may or may not match your original batch. The "proper" way to fix this would be to have a body shop custom match what is actually on your car. however, this may also be the worst option long term since the body shops do not use OEM paints.
2010 silver/black JSW TDI with DSG, 2011 red Golf TDI with dsg, 2003 red/gray Passat 1.8l gasser
kjclow is offline   Reply With Quote
Old December 16th, 2014, 12:31   #42
JASONP
JASONP's Avatar
You sir are correct and I explained to the service manager that this should have been looked at during R&D phase prior to production not after the sale.
They've ordered a new door and custom match to body paint and yes the metalic are completely off.
Old January 1st, 2015, 20:31   #43
Marsupial
Has anybody heard about that VW recall #24Bi? It definitely includes 2015 Golf but I'm wondering if it includes TDI variety.
Marsupial is offline   Reply With Quote
Old January 2nd, 2015, 08:47   #44
Matt927
Matt927's Avatar
TDI(s): several
Components:
FUEL SYSTEM, GASOLINE:FUEL INJECTION SYSTEM:FUEL RAIL
Matt927 is offline   Reply With Quote
Old January 2nd, 2015, 10:15   #45
Marsupial
Originally Posted by Matt927 View Post
Components:
Thanks. I saw couple articles about it but none of them specified fuel type.
Buying a 2006 2.5l TDI (R5) - Looking for advice on common issues? rsd VW Touareg TDIs 2 June 23rd, 2014 15:37
CV Boot Issues Common? JBell VW MKVI-A6 Jetta Sedan (~ 2011+) 5 February 15th, 2014 02:26
Common issues at 250k miles bmccrea TDI 101 9 November 6th, 2009 13:22
Lag issues common arnd 90000? What 2 tll dealr? ChadMad VW MKIV-A4 TDIs (VE and PD) 1 May 5th, 2005 19:14
(Early) New Years resolutions for my B4 TDIMeister VW MKIII-A3/B4 TDIs 4 December 23rd, 2002 07:29
Page generated in 0.21263 seconds with 11 queries
[Output: 130.83 Kb. compressed to 109.97 Kb. by saving 20.85 Kb. (15.94%)]
