Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 23rd, 2013, 11:05   #16
pdt165
Default FIXING 0s and 1s
2011:
133,500 MILES - Dozenspeed - Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 2 -DPF: 1 -HPFP: 1 -Note: original clutch and brakes
41,650 MILES - PDT165 - Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: Malone stage 1.5 Tune
36,000 MILES - Torrimac - Verison: DSG LE - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2012:
29,000 MILES - jetta12tdi - Verison: DSG Premium - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2013:
18,400 MILES - SkeeterMark -Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: 2013.0
18,100 MILES - tjdeerslayer37 -Version: 6MT- Premium w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
6,545 MILES - Locnar -Version: 6MT Premium w/ nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: 2013.5 w/ soft dash
2014:
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
pdt165 is offline   Reply With Quote
Old July 23rd, 2013, 13:18   #17
SkeeterMark
SkeeterMark's Avatar
Fuel Economy: See Sig
Cool. The binary code has been corrected.
[URL="http://www.fuelly.com/driver/TDISkeeter/jetta"][IMG]http://badges.fuelly.com/images/sig-us/172184.png
SkeeterMark is offline   Reply With Quote
Old July 23rd, 2013, 15:14   #18
Dozenspeed
Dozenspeed's Avatar
Fuel Economy: $10,457 per TB change
Originally Posted by pdt165 View Post
Based on what OP said, the number is what "item" you are on. Thus most of us are on '1' unless you have had them replaced meaning you would be on '2'
ALL:
I just made a new post and switched all the 0s to 1s assuming that is what was meantby the poster. I didnt mess with the existing 1's as it appeared those posters where thinking what the OP meant
Yes!, Perfect, thank you. The idea is to show how often the "worry items" are actually being needed. So if YOU just bought the car new, all the values are "1" -meaning "original, first one from factory" -for owner, TB, etc..... Warranty repair/defective replacement items DO count.
Next person: Post 16 is perfect, one to use next.
PS I did consider MPG, but feared I was pushing my luck, and so many of us have that listed elsewhere.....
Dozenspeed is offline   Reply With Quote
Old July 23rd, 2013, 15:18   #19
Locnar
Locnar's Avatar
Fuel Economy: 41-ish
Also, I'm optimistic that HPFP stat STAYS at '1'
Locnar is offline   Reply With Quote
Old July 23rd, 2013, 18:01   #20
Savageman69
Savageman69's Avatar
65,244 MILES - Savageman69 - Verison: 6MT Highline(cnd) w/o Nav-Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2012:
2013:
2014:
2012 Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
2006 Jetta TDI 5pd
Savageman69 is offline   Reply With Quote
Old July 23rd, 2013, 18:14   #21
JohnWilder
Fuel Economy: Average 53.25 mpg (4.4 l/100 km) over the last six months.
OK fellows,
I've a very stupid question. What is a MK6 Jetta? Do I have one? Mine is a 2003 Jetta.
JohnWilder is offline   Reply With Quote
Old July 23rd, 2013, 18:59   #22
Dozenspeed
Dozenspeed's Avatar
Originally Posted by JohnWilder View Post
OK fellows,
It means 6th generation, that came out for 2011. Yours is a MK4, and doesn't have a HPFP or a DPF.
Do you have a MK6 Jetta SEDAN? (2011-2015) Contribute to our mileage thread here! Over 70 cars and 3.5 million miles of data!
Old July 23rd, 2013, 19:22   #23
Jayg
Jayg's Avatar
36,000 MILES - Torrimac - Version: DSG LE - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2012:
29,000 MILES - jetta12tdi - Version: DSG Premium - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
14,500 MILES -Jayg - Version: 6 speed Base - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: Trunk leak, went to 2 dealers 6 times and it was finally resolved as defective taillights
2013:
2014:
Jayg is offline   Reply With Quote
Old July 24th, 2013, 05:35   #24
CNDTDI
CNDTDI's Avatar
Fuel Economy: 33/45/55
2012:
50,000KM - CNDTDI - Version: 6MT Confortline - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: intercooler recall
2013:
2014:
2012 Jetta with 57K KM 6 spd manual
sold 98 jetta 295k KM
sold 91 golf odo died at 400k KM
any idiot can face a crisis, its this day-to-day living that wears you out.
CNDTDI is offline   Reply With Quote
Old July 24th, 2013, 07:27   #25
fon462
Fuel Economy: 49
2012:
56,000 MILES - jetta12tdi - Version: 6mt - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: horn replaced
2013:
2014:
fon462 is offline   Reply With Quote
Old July 24th, 2013, 08:47   #26
pstroms
2012:
29,080 MILES - pstroms - Version: DSG Premium - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2013:
2014:
pstroms is offline   Reply With Quote
Old July 24th, 2013, 09:03   #27
pdt165
2012:
31,000 MILES - CNDTDI - Version: 6MT Confortline - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: intercooler recall
2013:
2014:
Old July 24th, 2013, 09:03   #28
pdt165
Above post I fixed CND TDI to miles and added fon 462 correctly.
Old July 24th, 2013, 09:19   #29
SkeeterMark
65,244 MILES - Savageman69 - Verison: 6MT Highline(cnd) w/o nav-Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note:
2012:
56,000 MILES - fon462 - Version: 6MT - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: horn replaced
31,000 MILES - CNDTDI - Version: 6MT Comfortline - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: intercooler recall
14,500 MILES -Jayg - Version: 6MT Base - w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: Trunk leak from leaky tail lights.
2013:
2014
Last edited by SkeeterMark; July 24th, 2013 at 10:00. Reason: Format, shorten note
Old July 24th, 2013, 09:20   #30
SkeeterMark
almost
AZNWHIP's 2011 CW Mk6 TDI Build Thread aznwhip VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 166 September 16th, 2014 20:35
May 2013 Mileage Thread Juergs TDI Fuel Economy 118 June 8th, 2013 16:59
The "What did you pay for your Mk6 Jetta TDI" thread ~Jb VW MKVI-A6 Jetta Sedan (~ 2011+) 126 November 8th, 2012 15:23
WTT: Portos (MK6 Golf) for Mambos (MK6 Jetta) dean_park Private TDI Items for Sale/Wanted 7 July 29th, 2012 19:59
May 2010 Mileage Thread Juergs TDI Fuel Economy 129 June 7th, 2010 06:02
Page generated in 0.23867 seconds with 11 queries
[Output: 140.40 Kb. compressed to 118.79 Kb. by saving 21.61 Kb. (15.39%)]
