Old June 28th, 2019, 14:21   #121
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
You may or may need a VCDS, this thread has a lot of AC diagnosis, but it was written for the A4
Check your radiator/condenser fan operation NOW
BobnOH is online now   Reply With Quote
Old August 15th, 2019, 13:24   #122
dpope
dpope's Avatar
Has anyone tried an OBD Eleven Scanner? Are they decent?
<-- Me being thrown out of a helo
In my younger days
dpope is offline   Reply With Quote
Old August 15th, 2019, 18:00   #123
Lightflyer1
Lightflyer1's Avatar
All ready threads here about it. Those that have it seem to think it is okay.
Old August 16th, 2019, 14:04   #124
BobnOH
not-a-mechanic
It is a popular OBDII solution for our cars, but VCDS is still the best bang for the buck.
Old August 19th, 2019, 11:33   #125
Teamzarz
TDI(s): 2009 JSW
I checked the maptive link and everyone that VCDS is pretty far from me.
Anybody in Central florida near the coast have VCDS where I don't have to drive all the way to Lake Mary? I'm near Daytona Beach. I need to check whether my AC HP sensor is bad or do a fan output test to make sure my fans function.
Teamzarz is offline   Reply With Quote
Old August 19th, 2019, 13:05   #126
Lightflyer1
44 miles isn't that far really. Hope you find someone you feel is closer though.
Old August 20th, 2019, 09:47   #127
Teamzarz
TDI(s): 2009 JSW
Talking
Its far in florida heat with no A/C
Old August 20th, 2019, 16:43   #128
Lightflyer1
My 1935 ford has no air or heat and I drive it more than that on the weekends just for fun. I would bet Texas is hotter than Florida.
Old August 20th, 2019, 18:32   #129
Teamzarz
TDI(s): 2009 JSW
Check the misery index on that, depends on where in Texas. The humidity is so high where I live (swamp) sweat and wind do little to help.
Also I was born with a rare genetic disease that makes me allergic to Florida....
That last thing was a lie.
Old August 21st, 2019, 14:00   #130
BobnOH
not-a-mechanic
Wimps, we drove for almost 20 years with no AC. Lived in Georgia part of that time.
Old October 15th, 2019, 10:39   #131
Iowa TDI
TDI(s): 2000 NB 247K
Fuel Economy: 45-50
Can i use a USB "c" to "b" adaptor with the non wifi Ross- tech products? My Surface only has a C type usb slot. I emailed ross-tech but have not heard back. Thanks
Iowa TDI is offline   Reply With Quote
Old October 15th, 2019, 10:57   #132
jef@rosstech
Associate Ross-Tech Vendor
Provided the USB C to A adapter meets specs, should not be an issue with a Windows 10 device. I'm under the impression some of the really cheap adapters are subpar.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old October 19th, 2019, 00:30   #133
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Iíve been using VCDS with a really cheap Windows 10 tablet ($99 at Best Buy) with a cheap USB-C adapter. Works fine.
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is online now   Reply With Quote
Old October 21st, 2019, 07:38   #134
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
I use an older MSI netbook running Windows XP-Pro only for the Hex-V2, nothing else, and it works just fine.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old October 21st, 2019, 15:07   #135
jef@rosstech
XP was shipped with computers from 2001 to 2009 as I recall, so that puts most XP machines out there at +10 years old. Ross-Tech does not support XP. We do not do anything to prevent the current version of VCDS (19.6.2 at this time) from working on XP machines.
Jef blah blah blah
www.Ross-Tech.com
Which VCDS Trimmy OBD Scanners 4 February 27th, 2013 23:22
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 12:15
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 22:21
used VCDS? ajbowman OBD Scanners 3 September 15th, 2010 19:06
Did I do this with the VCDS? Turbine Suburban VW MKV-A5 Golf/Jettas 1 August 9th, 2009 11:52
Page generated in 0.17867 seconds with 11 queries
[Output: 124.72 Kb. compressed to 103.55 Kb. by saving 21.17 Kb. (16.97%)]
