NWVintage
So, I went to the tire shop yesterday and had my winter tires taken off and swapped out for my summers (protecting my warranties). When we took a look at the summers, one had very significant wear on the inner edge. I was shocked to discover this and luckily the winters were only on for about 1.5 months, so didn't experience any obvious wear issues. My tire guys have a great replacement program, so they covered the one tire but I still had to buy one to match ($235), the week after replacing the trans for $3k and with a $200 alignment still on the horizon...
I have scheduled an appointment with a reputable alignment shop (highly recommended by a number of racing clubs) for next week. The issue is that, upon visual inspection, the only wheel that is exhibiting a strange amount of toe-in is the PS rear (LHD vehicle). The most likely culprit (on my thinking) is a bent stub axle. Is there anything else that may be the issue? Something that they'll be able to adjust during the alignment? (yes, it's a real alignment shop and they will be doing a four-corner alignment). I'm just wondering if I would be an idiot to hope that they'll be able to adjust this issue during the alignment or should I just bite the bullet and do the stub axle.
Normally, I would just do the stub for good measure but I just had to swap the transmission last week and I quite simply have other projects that I'd like to spend some time/money on instead of the Jetta...
