Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old July 31st, 2019, 19:24   #286
jhonster
Fuel Economy: 42-50 mpg
Originally Posted by Mike14VW View Post
Whatever you guys wanna think, changing the clogged/dirty fuel filter will maximize air/fuel ratio and as result, gas mileage will increase.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Thatís just an incorrect statement. The maximizing of the A/F ratio is done by the oxygen sensor & the feedback controls. Stoichiometric fuel mixes come from the emissions system toggling rich/lean to achieve stoichiometricity & thus maximizing the air/fuel ratio. A plugged or restricted fuel filter will usually affect power, but you can still have a maximized air fuel ratio.
jhonster is offline   Reply With Quote
Old July 31st, 2019, 19:40   #287
jhonster
Originally Posted by oilhammer View Post
LOL, you guys kill me. Seriously, if any 4 cyl TDI was getting 29 MPG you'd have a constant black cloud following you around. There simply isn't any way the engine could consume that much fuel. Or you have a fuel leak.
So. Iíve been meaning to post this for a while now.
Bought a 2013 Jetta sportwagen TDI in Feb of this year. Had a 2010 before this one that always got high 30ís (38mpg) on average. This one on the other hand has been getting 22-25mpg since I bought it. It had 93k when I bought it. Supposedly had the emissions update done (sticker under the hood). And the hi pressure pump just failed which was covered by VW about a month ago. So, with 98k on the car, and the timing belt 30k away, I had the dealer also replace the timing belt, tensioners, water pump, etc. I was hoping after all that work, that the mileage would pickup back to what my 2010 used to get. I drive mostly freeway & steady state 75-90mph. The car runs great & has plenty of power. Although the check eng light just came on & has stayed on. Code P2002 (8194 fac VW code) particulate trap bank 1 efficiency below threshold. The light 1st came on last Friday & it hasn't gone off. It's failed the testing parameter 4 times now. Any common failures that cause this issue where MPG is around 22?
Old July 31st, 2019, 23:27   #288
Lightflyer1
Lightflyer1's Avatar
I read another post saying clogged dpf's can cause this. Either not regenerating properly or clogged or something else broken causing this to occur.
Old August 2nd, 2019, 16:16   #289
jhonster
But the mileage issue has been constant since I bought it in Feb. The check eng light issue with the DPF is just within the last week. Iíve been tracking the mileage since I bought the car 5 months ago.
Old August 28th, 2019, 11:33   #290
jhonster
Well. Iíve got a 2013 Jetta Sportwagen TDI that is currently getting 23 to the gallon. Yup. Itís been that way since I bought it in Feb of 2019. Iíve checked every tankful for months & thousands of miles. Itís crap.
I had the high pressure Fuel pump just crap out & the dealer replaced it at no charge. Had them do the TB, tensioner & water pump at the same time. The emissions update was done before I bought the car (sticker is there under the hood). The Ck eng light just recently popped on & the car has both a catalyst low efficiency code & an EGR code as well. Iím just going to take it back to the dealer & tell them to fix the check eng light & complain about the terrible mileage.
Old August 28th, 2019, 12:08   #291
_Colty_
Fuel Economy: 52.5mpg on my 48 mile round trip to work. Stop and go on the way back too. :)
Was getting 40-44mpg. Got a CEL for DPF efficiency blah blah. Warranty magic and 50-55mpg. Mine is a 2 door manual and I engine brake like a crazy person and draft a reasonable amount, but it made a big difference. VW will likely warranty it if you even have a "pending fault" which a cheap $12 amazon OBD2 to Bluetooth scanner (with Torque pro) will be able to tell you about.
2011 Golf TDI 2 Door 6MT - Things wrong 0 -
1998 Cabrio 5MT - Things wrong (at least) 4 - Simple enough, but need more time
1997 Golf 5MT 4 Door 2.slow - Things wrong - 1? 2? 3?
_Colty_ is offline   Reply With Quote
Newbies and Vets: Tips for better fuel economy! BleachedBora TDI Fuel Economy 952 June 20th, 2019 09:24
Fuel Economy Tips Ric Woodruff TDI Fuel Economy 25 December 6th, 2012 09:22
2010 Fuel economy tips HansenTDI TDI Fuel Economy 8 December 30th, 2010 07:40
Fuel Economy tips from VW amorfeusz TDI Fuel Economy 40 August 15th, 2004 13:10
Economy Tips valois TDI Fuel Economy 17 February 23rd, 2000 07:09
Page generated in 0.14450 seconds with 11 queries
[Output: 80.47 Kb. compressed to 71.05 Kb. by saving 9.42 Kb. (11.71%)]
