Old October 22nd, 2011, 23:22   #1
bikerboyriley
bikerboyriley's Avatar
Fuel Economy: 46 mpg
Default Besides a slide hammer what is the best way to get out injectors?
I have a slide hammer but cannot locate a 14mm 1.5 pitch coupling nut, apparently nowhere in my town seems to have anything. Is there any other ways to remove them without causing any damage?
bikerboyriley is offline   Reply With Quote
Old October 22nd, 2011, 23:51   #2
Sbeghan
Use, I think, a 15mm open ended wrench. Notice that the injector has flat sides. Wiggle it side it side a couple times and gently pull on it while wiggling, it will usually pull out.
Sbeghan is offline   Reply With Quote
Old October 22nd, 2011, 23:58   #3
Seatman
Seatman's Avatar
Fuel Economy: No idea
Yeh I used a spare fuel pipe and screwed it on most of the way to give me something to pull on then did as above with an adjustable spanner, they came out fine and that was a 95 plate car in Scotland, land of rain and salt.
Seatman is offline   Reply With Quote
Old October 23rd, 2011, 09:05   #4
KERMA
KERMA's Avatar
To get the correct injector nut, I sacrificed one of the several injector lines that somehow accumulated in my garage over the years. Add a cheap harbor freight slide hammer, and it works great. Nowadays, DBW invented a clever little lever-type device he lends out with his hot-swaps. Might want to ask him if he has a pic
HP is for show, TQ is for go.
celebrating http://www.kermatdi.com since 2002
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old October 23rd, 2011, 09:10   #5
jetta ,97
jetta ,97's Avatar
Fuel Economy: Very good
Simple , Safe and good price:
Shttp://www.kermatdi.com/servlet/-strse-239/TDI-Injector-Slide-Hammer/Detail
BTW, tie rod end has same thread(14mm 1.5 pitch).
I do any repair on all models,USED/NEW ECU and Cluster swap, Reprogramming Keys , Immobilizer Delete,Cluster LCD Dispay Repair -Clik here
I am trusted TDI Mechanic, VCDS
HEX+CAN
ECU TUNING-TDTUNING Authorized Dealer
MK6 Needle Sweep,MK5 with MK6 Cluster
jetta ,97 is offline   Reply With Quote
Old October 23rd, 2011, 09:12   #6
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
The same thread is used at the top of your front struts... If you've ever changed them, the new ones should have come with new nuts, and if you're like many here, you still have the old ones kicking around... Just find someone to weld one of them to something that fits on your slide hammer...
Yuri
Quando omni flunkus moritati
ymz is offline   Reply With Quote
Old October 23rd, 2011, 09:34   #7
bikerboyriley
I would buy the slide hammer from kerma but I am just in a bit of a pinch and need it done this weekend. I have yet to replace my struts but I phoned my local vw dealership to see if they had any bolts but they did not. I am going to try the wrench method and hopefully none of mine are seized in too much!
Old October 23rd, 2011, 09:36   #8
Canadian_Grizzly
Canadian_Grizzly's Avatar
TDI(s): 02 Jetta TDI
Best tool = patience
Byron
Driver Found!
"There is lots of work to be done, if we are to achieve the kind of society people have the right to expect." Tommy Douglas
Having trouble with limp mode... Troubleshooting Low Power
Having trouble searching? Read this thread on advance search in forum http://forums.tdiclub.com/showthread.php?t=133579
Canadian_Grizzly is offline   Reply With Quote
Old October 23rd, 2011, 14:22   #9
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
http://www.runonbeer.com/puller.html
runonbeer is offline   Reply With Quote
Old October 23rd, 2011, 15:29   #10
vwdsmguy
Fuel Economy: 49/46/42
Default slide hammer
I got mine out by using the most appropriate bend of the 4 fuel lines. I then used a wrench on the injector flats to wiggle it back and forth while pulling up on the connected fuel line.
'02 Golf TDI, RC5, PP764's, FMIC, 2.5" T-Back, OMI, SB-3 clutch, 11mm pump, VNT17/22, 3 Bar MAP, CAT filter, 90 GPH Holley lift pump, modded D24 intake manifold, Rosten rods, Nural pistons, ported head - 15.0 @ 94 at the drags
vwdsmguy is offline   Reply With Quote
Old October 23rd, 2011, 17:13   #11
Seatman
Seatman's Avatar
Exactly the same as me.
Old October 23rd, 2011, 17:56   #12
ymz
Have you priced a new injector line lately?
Y.
Old October 23rd, 2011, 17:59   #13
VWBeamer
Fuel Economy: 42.79 mpg Woot!
Place an old blanket over the engine and turn it over, the compression will blow them out.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old October 23rd, 2011, 18:00   #14
VWBeamer
I made that last post up....
Old October 23rd, 2011, 18:02   #15
Seatman
Seatman's Avatar
Y.
No but they're very easy to steal from a parked car
How many do you want? Which engine code? I keep forgetting i live in the land of plenty.
WTB/Rent "slide hammer" to for injectors 43612 ajrn Private TDI Items for Sale/Wanted 1 August 21st, 2011 15:07
How to make a slide hammer adaptor for injectors? rhinotalon VW MKIV-A4 TDIs (VE and PD) 4 August 3rd, 2011 12:41
anyone have a slide hammer for injectors in the LA area? kooyajerms West Coast Canada/USA 11 May 25th, 2008 22:46
Help: Need Slide Hammer for 2 seized injectors: Spokane, WA torahtom West Coast Canada/USA 21 July 11th, 2007 20:18
Help: Need a Slide Hammer to pull out 2 seized injectors torahtom VW MKIII-A3/B4 TDIs 6 July 5th, 2007 13:42
Page generated in 0.20224 seconds with 11 queries
[Output: 126.52 Kb. compressed to 105.29 Kb. by saving 21.24 Kb. (16.78%)]
