Old July 13th, 2011, 07:31   #1
BRADFORDKO
BRADFORDKO's Avatar
Fuel Economy: 47.5 City
Talking VCDS or Not to VCDS, THAT IS THE QUESTION
I own a 2004 Golf TDI (BEW) Engine code.
I just finished replacing my timing belt, water pump, timing belt tensioner. I got the deluxe kit from Dieselgeeks http://www.dieselgeek.com/servlet/StoreFront
Car runs great. It took me almost 8 hrs due to hot weather working outside. My question is must I set the timing or not. I do not own the VCDS software.
Ross-Tech web site seems to state that if I own a 1.9 PD engine the timing is determined electronically.
http://www.ross-tech.com/vag-scope/TDIGraph.html
Near bottom of the page it says this:
Note to 1.9 PD (pumpe duese aka unit injectors) and CR (common rail) owners: The timing in PD and CR engines is determined electronically by the ECU. There is neither a need nor an ability to check timing on the PD or CR engines using VAG-COM.. There are no graphs published for the simple reason that the timing is set using a dedicated VAG locking tool when changing the timing belt :-)
So, should I check timing or attempt to adjust with VCDS? I beleive my mileage has gone down slightly, but working on my second tank after the timing belt change and will know better this tank.
Ken
Plattsmouth, NE
2004 Golf TDI
BRADFORDKO is offline   Reply With Quote
Old July 13th, 2011, 07:44   #2
K.I.T.T.
K.I.T.T.'s Avatar
TDI(s): N/A
The timing should be pretty much spot on, but it maybe worth checking (and adjusting if necessary) the torsion value.
Here's a how to:
http://www.myturbodiesel.com/1000q/m...t-Idle-TDI.htm
The suggested range is 0 to +1 degrees KW.
http://forums.tdiclub.com/showthread...ght=pd+torsion
Ash
PD injector differences (click)
K.I.T.T. is offline   Reply With Quote
Old July 13th, 2011, 08:30   #3
travism
travism's Avatar
If it was in time before and you did everything mechanically correct then you are good to go. Just find a vag-com around you and have someone check it. You'll know if its not in time.
2002 Jetta Wagon GLS TDI, H&R race springs, r32 struts,ventectomy,15% tint.
travism is offline   Reply With Quote
Old July 13th, 2011, 09:53   #4
abctdi
abctdi's Avatar
If your mpg remains the same, you are done.
05 Passat GLS 2.0 PD, UnChained & Steel GPs by VW, 15" steelies, New TB/WP, motor mounts, alt pulley, trans filter, cv boots, TSB #P9/66C8, clear bra & tint, both raxles. Now only driven 1-2 times per week. 123k miles (sold)
DD is a 2012 Kia Optima SX turbo with 274 hp and 269lb-ft@1,750-4,500rpm
abctdi is offline   Reply With Quote
Old July 13th, 2011, 10:27   #5
jcrews
jcrews's Avatar
TDI(s): All gone
If you happen to come across one, you can check engine measuring group 004 value 4 (torsion angle). It should be as close to 0 as possible. The angle represents the cam and crankshaft positions relative to each other.
jcrews is offline   Reply With Quote
Old July 15th, 2011, 21:36   #6
BRADFORDKO
BRADFORDKO's Avatar
Red face
I scanned it with VCDS lite:
Group 4: 903rpm 4.0 btdc 6.6 idle stab 0.5 Idle Stab
item 1 item 2 item 3 item 4
I read that 0.5 is not too high to be concerned.
What do you think.
Ken
Old July 15th, 2011, 22:21   #7
jcrews
jcrews's Avatar
TDI(s): All gone
Good to go.
VCDS question 1Crew VW MKIV-A4 TDIs (VE and PD) 4 March 25th, 2011 07:49
VCDS Question Rocket23 OBD Scanners 5 January 16th, 2011 22:22
VCDS Question NL-TDI VW MKV-A5 Golf/Jettas 0 December 29th, 2010 17:19
VCDS question nedro018 VW MKV-A5 Golf/Jettas 3 May 29th, 2010 04:55
VCDS start-up question(s)...help AndyBees OBD Scanners 4 May 16th, 2009 16:45
Page generated in 0.17890 seconds with 11 queries
[Output: 80.72 Kb. compressed to 70.02 Kb. by saving 10.70 Kb. (13.26%)]
