Old January 3rd, 2011, 04:46   #1
deep_sing
TDI(s): golf mk4 tdi
Default Golf tdi 99 hard start from cold and yesterday won't start at all
My Golf tdi won't start from yesterday. It was having hard start problem since I have the car for servicing in Early Dec. After a week the engine cut off while driving and had to spray "easy start" to start the engine. Since then I was having hard start problem and yesterday it refuses to start at all.
Done 328k miles.
Car was taken back to garage after servicing to inspect. They replaced inline fuel filter but this didn't helped. I have taken it twice to garage they didn't seem find a fault.
1) Glow plug were checked. They were fine.
2) Glow plug light comes. I have borrowed vag com and adjusted the glow plug timer as well. The light stays longer but it doesn't help. Vag come report interminent MAF problem other than that no faults. The sensor temperature reported was similar to the outside temperature.
3) No problem to start when engine was hot.
4) Battery replaced during servicing as well.
Where do I go on from here?
1) I haven't checked if harness is getting supply from battery? Will that be first thing to check?
HNY... cheers
Where do I start now??
deep_sing is offline   Reply With Quote
Old January 3rd, 2011, 06:59   #2
puter
Fuel Economy: 57 mpg
Never ever ever use easy start or anything like it on these cars!
You will cause engine damage.
puter is offline   Reply With Quote
Old January 3rd, 2011, 07:04   #3
MethylEster
Fuel Economy: 63/47/41 - Best/Avg/Worst
Might be a starter issue. I believe the MKIV Golf TDI needs to spin the engine at >240 rpms before the fuel will be injected. On tired, old starters sometimes during a cold start up they just can't turn the engine over fast enough. The fact that once warm your car will start with no problems I think is the key to diagnosing this problem.
Also clean all your ground connections, even the one under the battery. It might just be that as well.
99.5 Jetta, 5 Spd, Kerma Tune, VNT-17/22, PP520's, 3 Bar MAP, PD Lift Pump, ARP Studs, Whitbread 2.5" DP w/ High Flow Cat, OMI, IDParts Upper and Lower IC hoses, DG Race Pipe, SBC Stage II Endurance, ( Boost Gauge, EGT, Oil Press ), EVO Skid Plate, Neuspeed 25 mm Adj RSB, Koni STR-T's, Eibach ProKit Springs, TT Bushings, Akebono Ceramic & Brembo Rotors, GTI Recaro's
MethylEster is offline   Reply With Quote
Old January 3rd, 2011, 09:38   #4
deep_sing
How do I check if its a starter issue?
Thanks.
Old January 3rd, 2011, 11:32   #5
MethylEster
Look at Puter's reply above in Post #2 in his signature. There is a listing for troubleshooting cars that won't start. I believe Post #7 of that article will get you started.
With 328K miles has your starter ever been replaced? Have the wire connections to the starter ever been cleaned?
Old January 3rd, 2011, 14:47   #6
deep_sing
As far as I remember it hasn't been replaced nor wire connections.
Old January 3rd, 2011, 15:24   #7
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
1st off, NEVER NEVER NEVER use ether in these engines!!!!!!! You WILL cause major engine damage!
Second, the first thing you do with a ALH that starts hard is check the IP timing with VCDS.Unless you know the timing is spot on, the rest will be a waste of time and money.
If it's the starter going bad, the engine will crank over very slowly in the morning. I had to replace mine at 250K.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 395K miles and climbing.
09 Jetta Gasser, autofailmatic. Backup car. 230K.
turbocharged798 is offline   Reply With Quote
Old January 3rd, 2011, 16:23   #8
Justin9212
When was the last timing belt done? If they did not time the IP pump correctly it would cause this issue.
Swiderski Motorworks INC. Williamsville, NY 14221
1999.5 Jetta GL TDI 5spd 332K White on Gray. Current DD
2001 Jetta GLS TDI 5spd 114K Black on Black. MINT (SOLD)
2000 Jetta GLS TDI 5spd 260K Black on Black. Clean (SOLD)
2000 Jetta GL TDI 5spd 346K Silver on Black (SOLD)
Justin9212 is offline   Reply With Quote
Old January 4th, 2011, 15:40   #9
deep_sing
How do I check the IP timing, mate? Is there forum link with details?
Old January 4th, 2011, 16:46   #10
puter
Did you go through the troubleshooting nostart link in my sig?
Also, you may already have engine damage from the ether.
Old January 8th, 2011, 06:05   #11
deep_sing
I have done some checks as suggested in your link but couldn't find anything.
Car won't start at all now.
1) Anti Shutter Valve is open.
2) Glowplug hardness is getting power.
Where do I go on from here mates?
Old January 8th, 2011, 06:08   #12
deep_sing
Also Ether was applied by AA. Also one more thing the car used to have duel fuel system running in Veg oil but system hasn't been used for last year or so? Could these be the factor as well??
Old January 9th, 2011, 11:59   #13
deep_sing
Can I go back to AA?? The ether was used by their Engineers.
Old January 9th, 2011, 12:49   #14
puter
I doubt you would have any success going back to the company asking for repairs, esp. since the repairs are expensive. If I were in your place I would get the car to a guru and ask them to check the engine since ether has been used on it.
http://forums.tdiclub.com/showpost.p...68&postcount=6
That link is in the post in my sig, have you gone through all of the troubleshooting there?
Old January 11th, 2011, 14:03   #15
deep_sing
Have followed your link done all other verification expect """First you want to verify that there is voltage at the fuel shut-off wire."" How do I do it??
Also any TDI gurus around Swindon, Wilts, UK area??
Cheers,
Page generated in 0.18896 seconds with 10 queries
[Output: 125.13 Kb. compressed to 104.57 Kb. by saving 20.56 Kb. (16.43%)]
