Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi SUVs (Q7 & Q5) and other V6 TDIs
Audi SUVs (Q7 & Q5) and other V6 TDIs Discussions area for Audi Q7 and Q5 TDI (2009+ in Canada & the US) as well as others with the V6 TDI such as the A6, A7 and A8 sedans.
Old October 5th, 2019, 13:29   #1
Magus
Default Overfilled engine oil and engine knocking
We bought a 2013 Audi q7 TDI (US model) About 2 months ago. after driving just over 2000Km (including a 1600KM camping trip towing 6000lbs) We noticed some oil on the garage floor. and then we checked the oil for the first time and saw that it was over the max. So we towed it to the Audi dealer, and it was diagnosed with a faulty rear main seal, (but Audi said we could still drive the car) and that the leek was not too bad. So we picked up the car and after 58KM we heard engine knocking and pulled over immediately. After a short conversation with the dealer, we called a tow truck and had it towed back to Audi. After 2 days they called us to tell us that the engine is toast. So my question is, is it possible that too much engine oil caused the engine to blow up.
Magus is offline   Reply With Quote
Old October 5th, 2019, 13:36   #2
Vince Waldon
Vince Waldon's Avatar
To answer this question it would be best to have a lot more details about what "toast" means.
Oil-starved? Coolant-starved? Broken valvetrain? Broken rods?
That said, over-filling can blow out seals, which if go undetected can lead to oil starvation.
Or, perhaps it was overfilling due to a head-gasket breach and it was coolant rather than oil that made the level look high.
Lots of possibilities.
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old October 5th, 2019, 13:45   #3
Magus
all Audi did was a sound diagnosis and that they need 15 hours to diagnose it properly.
also, it did not smock or leak any fluids.
and the knocking started instantly without previous symptoms
Old October 6th, 2019, 08:11   #4
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
Possible that the oil level rose due to a failure in the fuel system?
mannytranny is offline   Reply With Quote
Old October 6th, 2019, 10:39   #5
johnsTDI
Location: Canada,ont North America were Neighbours to usa
Fuel Economy: oh gosh alot better than burning Gasoline.?
Just curious does the knock sound change or go away with higher engine rpm?
Satan puts the Fear & Deceives You. If he wanted to hurt You. he would of done it already. Got it.?
"Give Jesus Permission to come into Your Life". & everything else including Your VW will like it.
https://www.youtube.com/watch?v=7DM2phi2-2shttps://www.youtube.com/watch?v=AKniy8CCKgs
johnsTDI is offline   Reply With Quote
Old October 8th, 2019, 08:02   #6
Midwesthick
TDI(s): A6, Q5, Golf
Fuel Economy: 32+
I’m hoping it falls under your extended warranty.
Midwesthick is offline   Reply With Quote
Old October 21st, 2019, 12:39   #7
Magus
it's throwing these codes
P0266
P0272
P0275
P0302
any idea?
Engine Knocking After Adding Oil leegravel VW MKV-A5 Golf/Jettas 3 July 26th, 2016 02:27
Engine Knocking After Adding Oil leegravel TDI 101 3 July 25th, 2016 21:35
Help pls identifying engine knocking (or hopefully clutch knocking) noise tothemax TDI 101 25 July 21st, 2015 08:16
overfilled engine oil? willdog1177 TDI 101 21 September 19th, 2008 14:46
Overfilled Engine Oil LagoonBlueTDI VW MKIV-A4 TDIs (VE and PD) 5 January 18th, 2004 09:02
Page generated in 0.13506 seconds with 13 queries
[Output: 79.05 Kb. compressed to 68.52 Kb. by saving 10.54 Kb. (13.33%)]
