Old October 9th, 2019, 02:53   #181
SkilledMilk
Matrix replacement shouldn't cost too much if done by an independent garage as it's a couple hours labour + the part. The main dealers quotes in the £1000's are based on it being a dashboard out job, which is not the case. You could always have a go yourself!
SkilledMilk is offline   Reply With Quote
Old October 11th, 2019, 02:03   #182
dejvid
Originally Posted by Adyzds View Post
Haven't replaced the heater core yet.
But I drove it 2-3k km and I was checking the DPF regeneration and afterwars I turned the heat on HI.
Result: not a single drop of coolant lost
Hi, can you explain the effect of switching the heater to HI?
Do you switch the heating on HI during regeneration or after? How long?
Thanks for the reply
dejvid is offline   Reply With Quote
Old October 11th, 2019, 06:47   #183
Spipa
TDI(s): Mk 7 GTD
Hi guys, an update from me:
After replacing the heater core, the heating worked perfect again. In the first couple of days, the coolant kept getting lower and lower, even after a short 10 min drive. I honestly felt devastated and paniced a little bit lol. But after like 3/4 days, the coolant level has stopped dropping and since then I have driven now about 1500km with multiple DPF regens and lost not a single drop of coolant since then. I am 100% certain that my problems have been fixed.
I would advise you guys to replace the heater core yourself, it is an easy job and only need 2 or 3 tools. When replacing it yourself, the cost will be €90 in total (just the heater core).
Spipa is offline   Reply With Quote
Old October 11th, 2019, 06:48   #184
Kennyboy993
Thanks for the update.
I have mine booked in for new matrix on Monday. I will report back
Kennyboy993 is offline   Reply With Quote
Old October 11th, 2019, 06:51   #185
Spipa
TDI(s): Mk 7 GTD
Good luck! How much have you been quoted for the replacement?
Old October 11th, 2019, 06:52   #186
Kennyboy993
Around £550 all in by volks works in Leeds.
I’ll let you know final cost
Old October 11th, 2019, 06:54   #187
Spipa
TDI(s): Mk 7 GTD
Alright, I hope it will solve all your problems aswell!
Old October 13th, 2019, 17:54   #188
BirdmanofTas
Hi @Spipa, some dropping of the coolant level is to be expected, as the system will take a little time to fill all the little air pockets left by the expulsion of the coolant when the issue occurs.. mine dropped from above the high mark on the tank to just below half way between min and max, but has stayed there for the approx 4000Ks since..
BirdmanofTas is offline   Reply With Quote
Old October 14th, 2019, 04:26   #189
Spipa
TDI(s): Mk 7 GTD
Hi BirdmanofTas,
I did read about others having their coolant level drop slightly after replacing the heater core, so at first I did not think weird about it. But in those 3 days the coolant went from max to below min like 3 times, that is why I started to worry lol.
Old October 14th, 2019, 06:28   #190
AdrianC
TDI(s): Golf VII GTD
Since replacing the core in mine, I've done 2000km approx and only now am I topping up the coolant level. Notice a slight drop off but nothing significant (about 200ml).
This was to be expected to squeeze out any air pockets.
I hope not to be filling it again for a long time.
Ill do a coolant flush during my next service - just to be sure.
I can tentatively say the issued is fixed.....
AdrianC is offline   Reply With Quote
Old October 21st, 2019, 02:48   #191
Kennyboy993
New matrix fitted and so far so good - 400 miles since and no loss of coolant at all.
Heater much more powerful also which is a bonus
Old October 23rd, 2019, 08:47   #192
Kamei1507
Had my cooling system flushed again cold air on non drivers side. Heater works full now. But still have oil temperature problems 120 degrees when driving 140/150 km/h before heater matrix problems 108 degrees think my oil cooler is bugged whith same crap that has the heater matrix plugged. I think eventualy i have to swap it too.
Kamei1507 is offline   Reply With Quote
Old October 24th, 2019, 12:14   #193
mm-rocco
TDI(s): MK7 GTD 2016
After 5000km i have coolant-issues again. This time the coolant is not blown out after a DPF. The coolantlevel drops under minimum and the an alert is generated on the MFA. As soon as i loose the cap pressure is released and the coolantlevel rises again. I am thinking of the EGR-cooler now.....
I am still confident that the heater matrix was related to my problem, being the first part
https://youtu.be/Mi3BnMo_F7g
https://youtu.be/j9cVRIpoMP0
https://youtu.be/KYPoK3WRado
mm-rocco is offline   Reply With Quote
Old October 24th, 2019, 16:57   #194
Spipa
TDI(s): Mk 7 GTD
Dang, you’re really out of luck.. has the dealer inspected your car again? What did they say?
Old October 24th, 2019, 21:26   #195
mm-rocco
Obvious the EGR-Cooler....inspecting the EGR is almost half the price of replacing the EGR. My dealership see's this as the next logical step.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Coolant Expansion Tank Kray-Z VW MKIII-A3/B4 TDIs 4 January 11th, 2011 08:15
Coolant Expansion Jug Cap wny_pat VW MKIV-A4 TDIs (VE and PD) 2 June 10th, 2006 09:36
Dirt in coolant expansion tank? Diesel Addict TDI 101 54 May 22nd, 2006 01:13
Coolant expansion reservoir.. silverbeast VW MKIV-A4 TDIs (VE and PD) 6 September 29th, 2005 12:39
coolant leak from expansion tank? Platinumbird30 TDI 101 4 January 27th, 2004 17:02
Page generated in 0.18858 seconds with 13 queries
[Output: 125.95 Kb. compressed to 105.53 Kb. by saving 20.43 Kb. (16.22%)]
