Old October 17th, 2019, 11:52   #1
bbfarmer
Default Loud squeal from left front wheel
Hi folks, 2015 GSW DSG with 70,000 miles. I'm getting a loud squealing sound from the left front wheel when I initially take it out of Park, which usually lasts for just a few hundred feet before going away. Only happens after Park - if I just put the car in neutral and engage/ disengage the parking brake, it doesn't happen. Car is still under warranty and I could take it in for warranty repair, but the dealer is not very close and if at all possible I would like to hold off for a few weeks until my needs/schedule better fit.
Any idea what would be causing this, and if I should still be driving it? Does Park in a DSG lock something up at the wheels instead of at the transmission, as an automatic does? When I jacked up the car and turned the front wheel by hand I didn't feel or hear anything out of the ordinary. Many thanks
Sent from my moto g(7) power using Tapatalk
bbfarmer is offline   Reply With Quote
Old October 18th, 2019, 08:43   #2
740GLE
Does the sound go away only with the parking brake or if you glide the brake pedal and a firm press it goes away?
It's not uncommon to have slightly squeaky brakes each morning. I wouldn't worry about it.
Also DSG just has pawl lock like any other auto transmission, nothing at the wheels or on the axles.
740GLE is online now   Reply With Quote
Old October 18th, 2019, 16:11   #3
ProfBrown
Fuel Economy: In the sig
The light braking squeak I can attest is a rather common thing. Mine do it when first starting to drive on really light brake application. To be honest, its not just first drive. If I am at work and go to leave for lunch it will do it again. Can't say why, but the brakes work, so I don't complain about it lol. A break squeak is just after all, a high speed vibration.
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is offline   Reply With Quote
Old October 19th, 2019, 17:54   #4
bbfarmer
Thanks for your replies guys. This is definitely not a light braking squeak, it's a full-on loud squealing that started about 15k into my ownership of the car. I mean, head-turning squealing. Also I just realized it goes away sooner if I turn the wheel sharply to the right.
Old October 23rd, 2019, 10:18   #5
740GLE
does the sound start if the car is stationary or does it have to be rolling?
Old November 5th, 2019, 10:51   #6
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
I'm wondering the same thing ^^^^^
My wife mentioned a squealing noise from that area the other day in our MK7 GSW. I couldn't reproduce after a full day of driving it so I'm at a loss. Car was stationary on ours and it was a little chilly. We have about 67k on the clock and the car has been solid since day one and 80 miles on it, which was like day 700 after it was in VW purgatory.
Mrrogers1 is offline   Reply With Quote
Old November 7th, 2019, 16:05   #7
bbfarmer
It happens when the car starts rolling. New info: I found out it goes away if I tap the brakes lightly, or if I swerve to the right
Old November 7th, 2019, 18:19   #8
johnsTDI
Location: Canada,ont North America were Neighbours to usa
Fuel Economy: oh gosh alot better than burning Gasoline.?
check Your steering Link bolts i actually had 2 work there way loose just enough to where i would hear a thump thump noise.
over bumps in the road problem went away after tightening them up.
Satan puts the Fear & Deceives You. If he wanted to hurt You. he would of done it already. Got it.?
"Give Jesus Permission to come into Your Life". & everything else including Your VW will like it.
https://www.youtube.com/watch?v=7DM2phi2-2shttps://www.youtube.com/watch?v=AKniy8CCKgs
johnsTDI is offline   Reply With Quote
Old November 8th, 2019, 07:08   #9
740GLE
tie rod connection on the LCA?
Loud humming coming from left front? chiefmoose VW MKV-A5 Golf/Jettas 19 August 20th, 2011 08:13
New Noise from Left front wheel RedDragon VW MKIV-A4 TDIs (VE and PD) 5 June 13th, 2011 08:48
Turning Left, Quiet, Straight, Loud, Right Really Loud! Snowman VW MKIV-A4 TDIs (VE and PD) 16 May 13th, 2006 19:33
Loud Thunk in Left Wheel Well (A4)?? Rob_Cozeman VW MKIV-A4 TDIs (VE and PD) 1 April 18th, 2005 10:21
R front wheel squeal ekkoh99 VW MKIV-A4 TDIs (VE and PD) 1 April 15th, 2002 20:06
Page generated in 0.15380 seconds with 13 queries
[Output: 92.24 Kb. compressed to 79.22 Kb. by saving 13.02 Kb. (14.12%)]
