Old October 2nd, 2019, 16:51   #31
thundershorts
Installed a German junk yard one with the dsg vent using the new brackets and new bolts. Total about 110 bucks.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old October 2nd, 2019, 18:58   #32
bigb
I did the same. Using a ratcheting box wrench on the upper mount bolts was a lifesaver for me as there are no holes in my grille like some to stick an extension and socket into. My used pan arrived missing a front tab for which they gave me 1/2 off and it didn't make any difference mounting it. The brackets, bolts and wrench cost more than the pan.
Brian...
bigb is online now   Reply With Quote
Old October 2nd, 2019, 20:22   #33
hskrdu
Thx for the quick replies. I have the rough road belly pan (5Q0 825 902B) and all the hardware. I've read the thread at MK7 and three over at the vortex. Using an old and small monitor, I can't see where the two brace supports bolt on underneath.Agree it looks uncomplicated, but I have only a short window of time on the lift during the upcoming day of install, so I was just hoping to get better details to expedite the install (and keep lift fees under an hour if possible).
For the reference of others that find this, the belly pan was $70 including shipping from Holland (it ain't much if it ain't Dutch), and new OE hardware and brackets were $37 from VW online (vwpartsvortex = Burlington VW in NJ).
Now: 03 Golf GLS TDI 5SPD & (hers) 03 Jetta GLS TDI 5SPD & 2015 GSW TDI 6M
Then: 99 Jetta GLS TDI, 94 Golf GL, 85 Golf GL, 85 Golf, 79 Rabbit C, 68 Beetle, 65 Beetle
hskrdu is offline   Reply With Quote
Old October 9th, 2019, 11:18   #34
armyschus
armyschus's Avatar
I installed the Evolution Import plate from ID Parts. A very good design and did not cost as much as the ECS Tuning plate. Not a fan of the cheap options you may find on ebay. It the cost savings worth the additional risk and costs to repair damages from road debris. Will being installing the ECS tunnel protection next.
https://www.ecstuning.com/b-ecs-part...446ecs01-01kt/
I travel to a lot of BSA camps and the road conditions on them should be left to vehicles with high ground clearance.
2005 Jetta TDI, Triptronic, Colt Stage 2 Cam, Malone Stage 1.5 tune
armyschus is offline   Reply With Quote
Old October 9th, 2019, 12:14   #35
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
When you have car in the air it will be apparent. It's real hard to get a good pic of where they go without the bumper out of the way and most of us installed from underneath, with bumper on.
Mrrogers1 is offline   Reply With Quote
Old November 10th, 2019, 16:44   #36
hskrdu
Mrrogers, were you able to find the rear exhaust cover for the GSW TDI (torsion beam) with part number 5G0 825 206 J per golfdave's thread on GolfMK7? The only ones I can find so far are for cars with IRS.
Old November 11th, 2019, 06:23   #37
TDI73
TDI73's Avatar
Hi, would you, please, provide a link for a Dutch site? Thanks!
15 Golf TDI 6MT
Past:
06 Jetta TDI 5MT (BRM)
99 Jetta TDI MKIII 5MT(ALH)
97 Golf MKIII 5MT
TDI73 is offline   Reply With Quote
Old November 11th, 2019, 08:20   #38
Mrrogers1
I couldn't and I don't know how much more it would help so I stopped looking. It's a cheap part though, which it was available for us MK7 TDI'ers. I almost wonder if it's not available on purpose though as our exhaust systems do generate/hold quite a bit more heat than any of the other models. I feel like someone fabricated a cover of some kind like it but the heat burned it or something.
Old November 11th, 2019, 09:56   #39
hskrdu
Originally Posted by Mrrogers1 View Post
I couldn't and I don't know how much more it would help stop looking. It's a cheap part though, which it was available for us MK7 TDI'ers. I almost wonder if it's not available on purpose though as our exhaust systems do generate/hold quite a bit more heat than any of the other models. I feel like someone fabricated a cover of some kind like it but the heat burned it or something.
Thanks for following up. It's odd that it's so hard/impossible to find. There was at least one person in golfdave's thread that had one, if I read it correctly, since he confirmed that the torsion beam item was different from the multilink, and exchanged his initial part with VW for multilink. I can't even find a picture of it online to compare with the common IRS version.
Old November 11th, 2019, 10:01   #40
hskrdu
I ordered mine from here:
https://www.autorecyclingkuijpers.nl/
My receipt shows:
"26,00 per piece" ($30), but shipping brought the total to $70. Still a steal compared to full price.
They pop up on ebay.de, too:
https://www.ebay.de/itm/VW-Golf-7-VII-5G-Alltrack-Unterfahrschutz-Unterbodenschutz-vorne-5Q0825902B/193094303319?hash=item2cf5513e57:i:193094303319
Old November 14th, 2019, 02:58   #41
JM Popaleetus
JM Popaleetus's Avatar
Any chance you could PM me the message you sent them? I have a friend who wants the skid plate for his new GTI. But they have all disappeared from eBay, and the auction you listed from .de doesn't ship to USA .
2015 VW Golf TDI SEL (DSG, Lighting and Driver Assistance Packages, Tornado Red/Titan Black)
2007 GMC Sierra 2500HD Classic (Duramax LBZ, SLT, Extended Cab, Summit White/Ebony)
2013 VW Passat TDI SEL Premium Buyback
2010 VW Jetta TDI Buyback
JM Popaleetus is offline   Reply With Quote
Old November 14th, 2019, 10:07   #42
hskrdu
JM- I emailed with Marcel Kessels. I'll PM you the email, but I only asked if they had the part number, condition, and cost for shipping.
His contact info:
Met vriendelijke groet,
Marcel Kessels
Autorecycling Kuijpers B.V.
Rieten 6
5986 PH BERINGE
06-50246504
077-3031570
info@ar-kuijpers.nl
IBAN nr: NL30ABNA0213386925
BIC Nr; ABNANL2A
Wtb: mk4 golf tdi underbelly pan and engine side cover PD Rig Private TDI Items for Sale/Wanted 3 February 6th, 2018 05:23
WTB... MKIV underbelly sideskirts. CustomShirt Private TDI Items for Sale/Wanted 12 May 29th, 2012 18:18
New Underbelly??? Rachelvwjettatdi TDI 101 3 December 18th, 2007 15:21
Underbelly Skid Plate for Passat deming VW B5 Passat TDIs 20 March 29th, 2005 17:44
Underbelly Skirts POWERSTROKE TDI 101 5 September 11th, 2003 20:17
Page generated in 0.18144 seconds with 13 queries
[Output: 117.62 Kb. compressed to 99.86 Kb. by saving 17.76 Kb. (15.10%)]
