im buying my parts bit bit and and im going to be putting in the fmic first with a stock turbo and then later installing the modified vnt 20 from kerma. will i need an adapter to connnect to the new turbo?
No, but you will need a length of straight 2 inch ID hose to connect the vnt-20 to the IC piping. You may need to trim the first pipe from the turbo outlet to the FMIC a few inches but that's it. Just ask for the PD pipe with the ALH silicone hose and should be all set.
