Chris_TDI_98
Here is a North American Mk3 bulb list:
Note: Bulb numbers taken from A3 TDI. B4 prob has added 2x side markers and 2x rear domes.
EXTERIOR:
Headlights 2x 9004 (single chamber) 2x 9005 & 2x 9006 (dual chamber).
Front turns 2x 1157. (Yellow Amber nice to have).
“3-pin LED Flasher Relay CF13” (eBay $2 free shipping) to replace the OEM “191” relay, in position 6 on the fuse/relay panel.
Ref: https://forums.vwvortex.com/showthread.php?7222631-MK3-led-blinkers-relay-question#/topics/7222631
Front FOG LIGHTS: 2x ????. (With metal reflector?)
Rear Fog Lights: 2x ???? (With metal reflector?).
Sidemarkers 2x 194.
Rear turns 2x 1156. (Yellow amber nice to have)
Taillights 2x 1157. (Red nice to have)
Reverse 2x 1156. (White)
License plate 2x 194.
*** All bulbs are white, housings are white or colored. If you install different lenses/housings, then it is your responsibility to put in the proper color bulb needed to produce the required color for its position/function: white, red, or yellow/amber . ***
INTERIOR:
Dome driver side K5618, search “44mm festoon” (osram 10w).
Dome passenger side W5W, T10, 194, 168, 2825.
Instrument cluster dash 2x “B8.4D” White. Source: https://forums.vwvortex.com/showthread.php?2862314-instrument-cluster-bulbs#/topics/2862314?page=1
Glove box ???? Reply to thread if you have this bulb number ***
Hatch/trunk Search “39mm festoon” (osram 5w stamped on fuse style filament bulb with pointed ends).
Rear side domes (option) 2x 194.
EXTERIOR:
Sidemarkers 2x 194.
INTERIOR:
