Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Other VW Group TD(I)s
Other VW Group TD(I)s To keep with the theme of VW Diesels, this message area is for discussion of other VW Group Diesels. Yes, TD's are also welcome.
Old September 5th, 2018, 13:46   #1
Leroy337
Default T5 transporter no power
Hi, first time user. I have a 2009 t5 transporter 1.9 brs engine. Looking for some advice, van has no power especially from cold start. Have checked maf, coolant temp sensor, map sensor, turbo actuator, boost leaks, vacuum leaks, n75 valve, fuel filter and air filter both new. When at motorway speeds the van is gutless and tends to surge a bit with power. Only thing I can find is the values in block 23 read very low. All -60 to -70. From what I understand this relates to a low fuel pressure from tank/ lift pump? This would make sense but haven't had chance to test just yet. Any advise appreciated. Thanks
Leroy337 is offline   Reply With Quote
EDL upgrade to T5 transporter gNobby Upgrades (non TDI Engine related) 1 November 25th, 2010 16:51
Vw Transporter T5 misfire t5lee Other VW Group TD(I)s 0 January 23rd, 2010 01:09
Transporter T5 and reprogramming? Furhat TDI Power Enhancements 1 March 8th, 2009 04:00
VW Transporter T5 The_Transporter Other TDI/Diesel Picture Gallery 14 January 9th, 2008 05:07
EURO VAN T5 / TRANSPORTER T5 transporter_man TDI Power Enhancements 0 October 19th, 2003 03:56
Page generated in 0.10838 seconds with 11 queries
[Output: 46.73 Kb. compressed to 44.05 Kb. by saving 2.68 Kb. (5.73%)]
