Old April 7th, 2012, 09:46   #1
Nathan Courtright
Fuel Economy: wagon - 44mpg avg at 125kmiles; sedan 49mpg avg at 82k miles.
Default Fuel Filter - HPFP Question
Hello,
Just did the 40k service on my '10 TDI Jetta SW. When changing the fuel filter, is it normal for there to be any amount of metal shavings on the top of the filter? A small amount of very fine almost sand like, but silver in color was on top of the filter. I've read that this can be a sign of potential problems with the HPFP, but is it normal for there to be any amount of material in here, or do I need to start calling my dealer?
-Nate Courtright
Patterson, CA
Nathan Courtright is offline   Reply With Quote
Old April 7th, 2012, 10:07   #2
Plus 3 Golfer
Plus 3 Golfer's Avatar
IMHO, if normal you shouldn't be able to "see" metal specks at the top of the FF. Something is wearing.
Did you take pics? Did it look like mine at about 26k miles? See this thread and this thread for my failure at 44k miles.
Within the month I'll be doing my 60k FF change. I can't wait to see the top of the FF. If I see metal, I will take pics, button it back up, and take it to the dealer as I need to get the damper recall done anyways.
Plus 3 Golfer is offline   Reply With Quote
Old April 7th, 2012, 10:09   #3
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
IMO, it is NOT normal to find visible metal particles in top of your fuel filter element.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old April 7th, 2012, 13:05   #4
53 willys
53 willys's Avatar
Not normal......your HPFP is going bye bye....
~2010 SportWagen~6sp Manual~
~Votex~Black Portos~H&R Sport~Diesel Geek Skid~Stage 3/CR 170 Turbo
HPFP Failures=1st @ 47,000 miles
Stock Turbo Failure 142,000
53 willys is offline   Reply With Quote
High Pressure Fuel Pump (HPFP) failure - not blamed on fuel birkie VW MKV-A5 Golf/Jettas 80 October 16th, 2014 10:03
Why not a return fuel filter to limit HPFP damage? redbarron55 TDI 101 1 November 27th, 2011 08:35
Question on fuel filtration and hpfp units. dsieme01 VW MKV-A5 Golf/Jettas 11 November 12th, 2011 10:09
HPFP/fuel filter question kenargo VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 4 November 11th, 2011 09:52
Return line filter for HPFP? dustingebhardt VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 9 November 1st, 2011 13:35
Page generated in 0.12508 seconds with 11 queries
[Output: 64.42 Kb. compressed to 57.80 Kb. by saving 6.63 Kb. (10.29%)]
