Faint "marble rolling in a tin" sound on accelerating
passat130
UK
Passat Estate Sport 130
Upon accelerating I get a very faint noise of which I could only describe as a glass marble in the bottom of an empty soup tin, imagine holding the soup tin at the top and swirling in a circular motion with your hand, the marble circles the bottom of the tin.
The closest post I could find which sounded like it was this
http://forums.tdiclub.com/showthread.php?t=98778&highlight=ringing+noise
Just wondering if this is the same sound or anyone can relate to this?! :)
Honeydew
Florida
13 Passat DSG
I had a similar occurence when accelerating and turning right- a pebble had somehow got in an was rolling around on my aluminum skidplate. It was suprisingly loud.
TurboSlug
California
2000 Jetta
Could be your fuel pump. I've heard stories of it sounding like "Rocks in a can" before they quit.
Granted I've never heard it before or had the problem (thank goodnes), but I'll leave this to better experienced professionals to explain.
(That is where on of the guru's chime in) :D
dr.diesle
Calgary
92 golf tdi/01 golf tdi /02 golf tdi/04 jetta wagon tdi/vanagon westy tdi
a balled up cat converter will give a similar sound but havent seen one yet on a diesle gassers all the time also the bearing on the alternator may give a sound like that check all pulleys and so on in belt drive ...
SoaceMunky
Webster, TX
Blue Anthracite Golf IV, 13 miles and counting ;)
Its cervesa bottle cap. I sometimes get that when I break hard. Every time I do maintenance on the car, I find spare parts hidden away... its like an easter egg hunt each time!
passat130
UK
Thanks for suggestions. It does have a faint ringing sound to it as well which is why I thought it may be the link in OP which quite a few people experience.
passat130
UK
car has just had an oil change, oil filter, fuel filter and air filter and the noise has gone. Hmmmmmm :confused:
sdeck
Northern Colorado Front Range
2003 Jetta, 253K, 01M, DLC520s, VNT-17(sold); 2014 Passat SE 6M, 61,000 miles (Feb 16 buyback date)
change the oil = drop the belly pan to remove oil pan plug = bottle cap gone
Ben1000
Greensboro, NC
2001 Baltic Green 5spd
That's one heck of a neat trick P130... if only all mystery sounds were so easy. :D
