First of all, thank goodness idparts has started selling a winter front again. I think they are a great idea for those cars in places that get winter. Ideally I think all our cars would have adjustable louvers on the front, controlled by a thermostat, but for cheap retrofits we can just try and adjust seasonally.
I've been meaning to post about another alternative to the pipe insulation method. This winter I decided to try using plastic ground cover, which is also super cheap (~$1.60 for way more than enough.) I removed all the grills, gift-wrapped them in the groundcover using gorilla tape to stick the plastic sheeting to itself around the grills, and then cut the plastic so that the tabs would still engage. It feels very seasonal! Happy holidays to your car... I'll just unwrap them in the spring.
Here's the center lower grill after wrapping, as an example. I put all the seams and tape on the inside/back of the grill (pictured):
And the finished front:
Obviously, I don't care a great deal about being the slickest looking TDI at the ski resort, or about the hour or two it took me to do all this wrapping. If I did, I would buy the front from idparts, although I'm still waiting for a photo that makes clear how much coverage it provides compared to what I've done here.
I basically blocked everything, and then winter here in Colorado didn't happen for a bit. I've been watching the coolant and intake temps on an Ultragauge and adjusting to try and match the coverage to the conditions. On a 70+ degree sunny day driving around town, coolant barely reached 200 degrees (not scary, based on what I've read in the thermostat mod thread), but intake temp was flirting with 120 which probably isn't good for making power. Most cool to cold drives have taken 6 miles or more to barely reach 180 coolant temp, and ~ 70 or 80 degrees intake temp (this is measured post intercooler, I believe.) I'm considering cutting a hole in the lower passenger-side cover to allow more cold air to hit the intercooler, but haven't done that yet. I can always just keep a roll of gorilla tape in the car and cover it up again if we get a cold snap. Subjectively, warm-up seems faster, but I don't use my car daily so it's been hard to tell. I think it could be useful for retaining cabin heat on those long downhills returning from ski trips, and of course I'm hoping it will help avoid some of the winter hit on fuel economy.
