Biodezl
The coolant flange on my 1999.5 Golf was repaired, at the dealer, under warranty, due to persistent coolant system leaks. I recently noticed a small crack on the coolant hose where it meets the coolant flange. I also noticed that the coolant hose seems to be severely stretched around the coolant flange...plausibly the cause of the split in the hose. I also noticed that the replacement flange is metal whereas the previous one was plastic. I presume that the metal one comes from a later model engine (2003+?). And so I also wonder if the hose that attaches to it also has a larger inside diameter.
Is there anyone out there with both vehicles, or someone that has both parts in stock? Could you please measure the inside diameter of this hose for me? Here are the two part numbers:
1999.5+ 1J0-121-109C
2003+ 1J0-122-109CD
Thank you!
2003+ 1J0-122-109CD
Thank you!
