cqpate
greetings
i have discovered my 'radiator fans' will not work, even with a drive around the block or with air turned on. all related fuses appear normal. cabin fans work normal. low pressure ac appears normal range.
ac clutch will come on and ac will slowly cool to 60deg(vent thermometer) after hour driving hiway speed with 95deg outside. will go to 40deg if morning is cool.
how much effect do theses fans have on ac temp?
02 beetle tdi 230k miles original compressor, new clutch disc
