Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old March 23rd, 2006, 10:09   #1
PWN
Default Biodiesel available in Gaineville Florida area (North Central Florida)
No retail fueling sites yet but we are working very hard on it. We can supply you with 5-6 gallon can(s), 55 gal. drum(s), any size skid tanks (285, 500, 1000 gallons) and custom tank builds. We can also supply hand pumps, AC/DC pumps, filter systems, Biodiesel compatible pump gaskets, etc.
It will take a few weeks to get custom order together.
www.freedomfuelsinc.com
B100 or any blend.
We are new and growing and supplying the need the best we can. Within several months we should have a retail type establishment on line, if not sooner.
In the meantime if you need some Biodiesel give us a holler.
'98 Jetta TDI - B100 since May 2003
'96 Passat Variant TDI - B100 since May 2003
'92 Dodge Cummings Power Ram W250 - B100 since February 2007
'22 Chandler Royal Dispatch
PWN is offline   Reply With Quote
Old April 4th, 2006, 18:46   #2
DMV
Default Pumps
Do you sell 12V transfer pumps for use in a truck bed mouted tank that will hold up to B100?
Bio-Diesel - The alternative fuel.
'95 GC Orvis 205k - '00 Dodge Dually 4x4 Cummins TD 105k
'06 LTD CRD Build 2/06 - '06 VW Beetle TDI Build 3/06
DMV is offline   Reply With Quote
Old April 6th, 2006, 08:12   #3
PWN
Yes. There are several models we can get. Low and high flow and models with and without meters, auto shut off, etc. For around 15$ we can include a nickle gasket kit that should be Biodiesel tolerant. We have used several AC pumps without the gasket kit and they are working well so far at about 6-8 months.
Page generated in 0.11909 seconds with 10 queries
[Output: 53.87 Kb. compressed to 48.53 Kb. by saving 5.34 Kb. (9.92%)]
