Old October 3rd, 2005, 16:04   #16
sleze
Fuel Economy: 30 MPG
Default Re: Frequently Asked Questions
I just bought the VAG-COM for my 2005 Passat. Should I have gotten it with CAN?
sleze is offline   Reply With Quote
Old October 18th, 2005, 14:18   #17
jurgen01
I have a body part related question.
I am not happy with the alignment of my bumper cover as it relates to the body. In order to correct it I need to remove the headlight assembly and prior to this I need to remove the center grill assembly. Does anyone know how to do this? There are two bolts to be removed and the rest seems to be some sort of snap in setup. I dont want to force anything it case it might break.
jurgen01 is offline   Reply With Quote
Old October 20th, 2005, 15:18   #18
Smokerr
Fuel Economy: 43.5/32/28
I am curious, is the Passat Wagon still being made until middle 2006?
I thought I saw that, but have not seen anything lately. The 2006 best mileage lists are out, the Passat Wagon isnít on it (or I have not seen it).
It doesnít seem to matter to me what model year designation the car is, if its still being made for the 2006 model year, then it should be included
Smokerr is offline   Reply With Quote
Old November 21st, 2005, 16:50   #19
sleze
Answer to my own question. Yes for the 2005 b5.5 Passat, you need the HEX-CAN VAG-COM to get access to everything.
2005 Shadow Blue Passat TDI Wagon GLS
RC2, Mufflerectomy, Ventectomy
-DECEASED-
www.thereheis.com
Old January 3rd, 2006, 10:45   #20
Sloppy Snood
Sloppy Snood's Avatar
TDI(s): Passsat
Fuel Economy: 31 mpg (city) / 38 mpg (hwy)
Default Chasis Desgnation and Part Numbers
Hello. nOObie Sloppy Snood here. I own a Northern Green 2005 Passat TDI GLS (2WD).
I am having trouble locating the correct chasis designation and associated part numbers for all the air, fuel, oil, and cabin filter part numbers.
TDIParts.com indicates my chasis is a B5.5 but I do not see part numbers specifically for this chasis. Please help me. -Sloppy
Sloppy Snood is offline   Reply With Quote
Old June 18th, 2006, 04:52   #21
IRONBOY
IRONBOY's Avatar
Fuel Economy: 28/33city 40/44 Hwy
Originally Posted by whizbyu
Hi I know there was a thread on how to change wiper blades using refills and a pair of long nose pliers. I tried the search but couldn't make it come up. Anyone have the link on this? Thanks!
If this vehicle is 05 Passat GLS TDI, you don't need any pliers to change the wiper blades. At least my don't.Just lift the wiper arms from the wind shield, flip the blade over to counterclockwise and slide it out.Replace it with the new one and turn it clockwise to lock in place and "viola"! you are done.
IRONBOY is offline   Reply With Quote
Old June 18th, 2006, 18:56   #22
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 3.3 Mi/kWh
And much lighter in your wallet. You can take the Aero blades apart and replace just the rubber blade portion. Generally costs about $7.
-Jason
Present:
2018 Tesla Model 3 DM. 20,000 miles.
2014 Cadillac ELR. 34,000 miles.
2013 Fiat 500e. 28,000 miles.
Past:
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG. Sold to JDSwann's Brother.
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old July 23rd, 2006, 18:46   #23
tdisedanman
All worked well except the blades didot want to come out. I finally sprayed some WD40 into the groove and let it seep for about 5 minutes. Then I tried to remove the blade from either side. It took awhile to work them free but I finally won the battle. I then cleaned the area with the WD40 and installed the new blades.
2005.5 jetta TDI - gone
2005 Passat TDI - gone
2011 E350 bluetec - present
tdisedanman is offline   Reply With Quote
Old August 7th, 2006, 01:43   #24
IRONBOY
IRONBOY's Avatar
Cool
Glad you finally won the battle.By the way, nice pics of the two "brothers" on your drive way .
05 PASSAT GLS TDI
Ultra Low Emission Vehicle
01 Jeep cherokee sport.15mpg SOLD.
M1A2 Abrams 1Mile= 5-8Gallons
85 MB 300D,344k and Counting...
Old August 23rd, 2006, 19:00   #25
IRONBOY
IRONBOY's Avatar
OK sloppy,these are the part numbers:
1 Air filter: 058-133-843
2 Cabin filtre:1H0-819-644-B
3 Fuel filter: 1J0-127-401-A
4 OIL filter: 074-115-562
I can't help but notice that you are a vet.This info is provided in exchange for your title .Please let me know when it's safe to dispose my newbie title and assume my new acquired veteran status
05 PASSAT GLS TDI
Old August 27th, 2006, 10:24   #26
dano0726
I'm trying to change the cabin filter on my 2005 Passat -- the Vortex article shows an older/different VW engine compartment having torx screws...
Am I missing something??? Does the entire one-piece plastic (from passenger side to driver side) come off to change out this filter -- I can see the filter, but I don't see the connectors. It looks like it goes all the up to the windshield glass, over the wiper arms.
How would an A/C mechanic get to the freon connection? How would I replace the battery?
I feel like a real newbie...
dano0726 is offline   Reply With Quote
Old August 28th, 2006, 16:11   #27
bigEZ
dude, chill! it's not that hard.
open the hood; locate the battery. see the trim/rubber seal underneath the battery compartment, that runs the width of the engine bay? pull it out just to the left (or passenger side) of the battery; the cabin filter is located in there and just slides out (you have to pull the plastic piece covering the battery up a little bit to get to it). the filter may be flow specific (ie, it may fit in there in a specific direction); i can't remember, but it will be pretty obvious, as there will be a top up up written on part. replace the seal (make sure it goes on good and tight).
by the way, a search for cabin filter or pollen filter in the b5 forum would have answered this question for you. cheers!
bigEZ is offline   Reply With Quote
Old August 29th, 2006, 06:49   #28
dano0726
Default Thanks for the help
BigEZ -- thanks for the help/pointers...I learned how to change out the filter
Old November 2nd, 2006, 00:57   #29
TDForNow
TDForNow's Avatar
Fuel Economy: (Passat) 41 mpg, avg, (Quantum) 45mpg. avg
He's talking about actually changing out the "rubbers" inside the "aero" wipers with $5-8.00/pr refills instead of paying $20.00 for EACH replacement blade.
BTW, here's the link: http://www.passatworld.com/forums/sh...d.php?t=127303
Alain
ABS, ASR, ASC, BSD, BSW, DMS, EBAS, ESC, ESP, EDL, ISA, LDW, TPS, TPW to bale their arses out ... and ONSTAR* and E-CALL to rescue them for "successfully" defeating any or all of these!!
REALLY!! .... Drivers Wanted!!
It's no wonder the OTHER animals haven't "evolved" away from survival of the fittest! ... Looking at our "progress", they know they're better off!!"
'99 Passat AEB GLS Wagon
'95 Passat GLX Wagon
'85 Quantum TD (RIP)
TDForNow is offline   Reply With Quote
Old February 7th, 2008, 20:16   #30
Boiler84
Boiler84's Avatar
Default BodyStyle codes
Originally Posted by icnick
Your new Passat is a "B5" platform car, or "B5.5" because it was made after the 2001 body revision. This refers to the platform of the car- Jetta/Golf/New Beetle/Audi TT are "A" platform cars- the current one is the A4 (1999.5-2005) platform, but the A5 Jetta has just come out. The Passats are larger "B" platform cars, currently the B5 (VW Passat 1998-2005, Audi A4), but the brand-new B6 platform is now available in europe, and will be here this summer. It is a larger car, and no longer shares the Audi longitudinal platform. It is transverse like the G/J/NB. Your 2.0l TDI-PD engine is engine code "BHW". HTH PM me if you have any other questions.
Nick
Go to wikipeida and ask for Passat. It will breakdown the coding for you.
2004 Passat Wagon GLS TDI, 101K miles
Form Fit Hood Protector
Boiler Up!
Boiler84 is offline   Reply With Quote
Page generated in 0.18166 seconds with 10 queries
[Output: 132.54 Kb. compressed to 111.06 Kb. by saving 21.48 Kb. (16.21%)]
