03tdiwagon
Hey guys I'm looking for a quick reply with input or knowledge to something I may be missing .
I have my car up on stands and I'm checking for runout on my front 2 rotors and hubs.
The issue is I took everything off ( caliper, pads) so it's just the rotor bolted to the hub on both sides of the car and the hubs/ axle shafts are very difficult to spin**.the point of the test is to see if my wheel bearing Is toast as I've been having lateral wear on my pads.*
1) should the hub be spinning on its own or should the hub and shaft be spinning together. I was thinking if its a good quality new hub it should spin freely by itself with no shaft movement. And if its a worn bearing /starting to seize it's giving me this issue where if I turn the hub the whole shaft spins also??*
Summary*
I understand it is a open differential and only 1 side spins ( whichever I'm rotating) but I don't understand if the hub should spin freely or with the axle shaft also under load. THANK YOU
Summary*
