joatmon
I noticed on my 2011 VW Jetta TDI (Automatic Trans) the parking brake handle feels a little loose when first pulling up on the handle. I can lift up the handle at least about 3 inches before feeling resistance. It did not use to do this before.
A couple of weeks ago I noticed that the handle could move about 1 inch before feeling resistance, so the issue has gotten a little worse. I can lift the handle a little without pressing the release button. Not sure if this is normal.
I only use the parking brake very occasionally. Is this a somewhat common issue? Any ideas?
(Sorry if this is covered in the forum. I tried a search with no luck)
