Old October 9th, 2019, 07:40   #16
50harleyrider
Can ayone tell me the "dry" capacity of the GMR? as time goes by on maintenance of these trannies, is the G052162A2 spec still what we should use? Pentosin ATF-1? Super expensive. Best price I've found is $13.50/L.
50harleyrider is offline   Reply With Quote
Old October 9th, 2019, 07:50   #17
oilhammer's Avatar
Fuel Economy: fantastic
Initial filling 9 liters.
Changing (which I assume to be just a drain and fill) 3 liters.
I know if you drop the pan and take the filter loose, it is closer to 5 liters to fill it back up.
We use Pentosin ATF1 here (there are other brands).
I think our cost on it (we purchase it in 20 L jugs) is about $11/per.
www.cardocautomotive.com
Old October 9th, 2019, 11:18   #18
Zambee500
FCP Euro has Pentosin ATF-1 priced at $60 per 5L shipped, no tax.
Febi and Ravenol can be found a bit cheaper there and elsewhere.
2005 Passat GLS TDI (sedan)
Zambee500 is offline   Reply With Quote
Old October 9th, 2019, 20:49   #19
50harleyrider
idparts sells at a good price too. I'm sure Corey would not put trash out there.
Dead automatic? 50harleyrider VW B5 Passat TDIs 24 September 21st, 2019 08:07
WTB: A-4 Golf TDI W/ dead automatic transmission Herm TDI TDI Cars for Sale/Wanted 8 March 2nd, 2012 14:57
Another Automatic Transmission dead Need help mal91152 VW MKIV-A4 TDIs (VE and PD) 7 November 1st, 2009 23:47
Mystery: Dead Radio, ... 2 week pass, dead battery? GdB VW MKIV-A4 TDIs (VE and PD) 22 May 1st, 2008 14:48
Dead 2000 Jetta TDI automatic DSL HED VW MKIV-A4 TDIs (VE and PD) 12 January 31st, 2005 13:29
Page generated in 0.14609 seconds with 13 queries
[Output: 64.74 Kb. compressed to 57.77 Kb. by saving 6.98 Kb. (10.78%)]
