eddels
Hi Guys,
Sorry for the first post asking some advice immediately a member since 2016 but never posted just following all the way from SA
Need some Advice:
Seat Ibiza Cupra 1.9tdi losing power after 4000rpm as if the fuel fades
Its holding boost though so it is for sure not boost. Its struggles to get to the 5000rpm limiter
Mods
Fmic, GT2260, full 76mm straight pipe, Firads 80%
Replaced so far
In tank pump
Fuel filter
Fuel/vacuum pump next to head
vacuum pump
cupra injectors replaced with injectors firads 80% from darkside
Tried mafless so it is not the MAF sensor
We suspecting cam as well but should that not affect the whole rpm range?
Please guys any ideas what the issue might be
Need some Advice:
Mods
Replaced so far
In tank pump
Fuel filter
vacuum pump
