m_skena
Anybody experienced this problem before on the MKVI? I see it was common with older VWs. I'm certain it's freezing after today. Read below for the story, if you're interested...
48 hours ago: left work and drove home. Once home temps quickly dropped into low 20s. Attempt to leave and find drivers side wheel is stuck after releasing the parking brake. Not just stuck.. wheel won't turn at all. Get the car out of driveway and start going forward/reverse and jamming brakes. Eventually it releases. Run the errand, return home, set parking brake.
Following morning: temps in the teens. Parking brake stuck again. This time, car up on jack, wife sit in car and maneuvers the lever while I manipulate the cable/spring by hand and it releases, after 20 minutes of messing with it. Hmmm. Left the brake off the rest of the day and overnight.
This morning: temps in single digits. took car to general mechanic (not VW guru, but close to home). Left it with him and got a ride to work. He calls me, can't find a reason why its sticking. Lubricates the hell out of it and parks it outside with parking brake on. I get there after work (temps in teens) jump in and the wheel is stuck again. Limp it into the warm garage after trying to break it free for 20 minutes outside. Leave it parked, suspecting that it's frozen and sure enough, three minutes later, its thawed and spins freely.
All the while... the car drives normally. Any thoughts?
