Is this pretty much the "standard way" to replace o ring; not having this info/detail I ended up forcing the cooler down off of the nipple as I knew it was possible to replace the o ring w/o removing the cooler, which in hind sight does not seem real smart(my method). Any body else care to comment??
Don't know if this is the standard way or not, but it's the way I found to do it without having to drain the coolant and wrestle with the spring clamps to free the cooler itself.
I've been in there a couple times, the filter stand gasket leaked and I replaced it but the second one leaked as well. The first time around I drained coolant and the second time I decided I wasn't doing that anymore.
I couldn't push the cooler down far enough to clear the nipple and I was worried about damaging the hoses. Second time around it dawned on me to go after the center section of the nipple with a vice grip. With the cooler pushed down it's easy to get to and with the nipple out it's easy to get the o-ring situated.
It's also the way I get the filter stand off too since the cooler blocks access to one or both of the bottom bolts (can't remember).
I'm sure the VW specified procedure probably requires draining the cooling system.
Steve
