Old November 15th, 2018, 19:52   #1
Giberish33
Default Cabrio driver door weather seal same as jetta?
Found 2 mk3 cabrios at a local junk yard, does anyone know if the door rubber weather seals are the same for cabrios and jettas?
Giberish33 is offline   Reply With Quote
Old November 15th, 2018, 21:23   #2
Steve Addy
TDI(s): 97 Mk3
Completely different, the Cabrio is hard top (no door frame around top of glass. Also, the Cabrio door is larger (more like 2dr Golf / GTI door).
A lot of the Cabrio weatherstrip is in the folding top so it's not going to be anything like the Jetta.
Sorry about that.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
the magic triangle spins in the peanut and then apex seals come out
Steve Addy is offline   Reply With Quote
Old November 16th, 2018, 07:54   #3
Giberish33
Sorry about that.
Steve
OK thanks Steve. What about mk4 jettas any weather seals applicable to mk3's. just trying to figure out if there is anything useful to grab while im there. I own a mk3 but there are tons of mk4s in the junk yard.
Old November 16th, 2018, 21:11   #4
Steve Addy
TDI(s): 97 Mk3
Never looked at door seals between the two but I doubt it's the same. The Mk4 is completely different beast. You could take a look though, but there's not much from a Mk4 that will work on Mk3 cars.
Steve
Old November 17th, 2018, 22:52   #5
garciapiano
Clean, untorn door seals for mk3s are quickly becoming unobtanium. I suggest grabbing every decent one you find. The rear seals are a little shorter than the front door seals so front door seals are more useful (you can cut em down with a dremel if need be.)
That being said nothing door-related from the Cabrio will fit, given that it is a convertible and the Jetta /golf is not.
Pretty much nothing from the mk4 will fit a mk3.
garciapiano is offline   Reply With Quote
Driver and front passenger door not latching in hot weather fr@nknb33n$ VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 August 2nd, 2017 07:11
Check rear driver side door seal. KraftwerkB6 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 11 January 22nd, 2013 19:01
Jetta Driver's Side Door Seal cbalthazor VW MKIII-A3/B4 TDIs 0 December 29th, 2011 16:52
WTB: Outer door seal for 04 Jetta driver side. 04SlvrJetta Private TDI Items for Sale/Wanted 1 April 21st, 2009 20:40
Driver's Door Seal fincoop VW MKIV-A4 TDIs (VE and PD) 4 April 13th, 2001 08:17
Page generated in 0.12789 seconds with 11 queries
[Output: 70.37 Kb. compressed to 62.50 Kb. by saving 7.87 Kb. (11.18%)]
