Old October 28th, 2018, 11:22   #1
clyde
Default Water pump
Searched for water pump; no results.
Need a new pump with cast-iron impeller. Have a good housing; don't need another. Thought the pump part # was 037 121 005C, but AutohausAZ shows that part has a stamped sheet-metal impeller.
Anyone know of a good part # for a Mk3 water pump w cast-iron impeller?
Thanks!
clyde is offline   Reply With Quote
Old October 28th, 2018, 12:09   #2
Steve Addy
TDI(s): 97 Mk3
The part number is good, 037121005C but impeller design will be up to the manufacturer. Some use stamped steel, some use cast but I'm not sure anyone does cast iron anymore. I have seen some with cast aluminum impeller and some with a synthetic impeller in the shape of the cast product.
Geba used to be the pump of choice a while back and based on the pics at ECStuning it looks like it still might use a cast impeller, but I would want to verify that with ECS before I purchased one if that's your preference.
Seems the last one I installed on the wagon was Geba but also I think I have a GMB in a box somewhere too, but I don't think that one has cast impeller.
Good luck
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
the magic triangle spins in the peanut and then apex seals come out
Steve Addy is offline   Reply With Quote
Old October 28th, 2018, 12:51   #3
clyde
Thanks, Steve!
With that part #(005C) ECS offers both cast and stamped impellers. A GEBA with cast and a Graf with stamped.
What's the performance record of the stamped impellers? Do they stay on?
Old October 28th, 2018, 15:24   #4
ToddA1
Fuel Economy: Dismal
I’ve had no issues with stamped steel impellers. I had a plastic cast Bosch pump, and the impeller started freewheeling.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old October 29th, 2018, 04:49   #5
Abacus
That helpful B4 guy
Abacus's Avatar
I’ve had two stamped impellers (Graf) fail early and a dozen more that we’re fine. I’ve also seen the cast ones fail, so nothing is immune. I refuse to install one with a non-metallic impeller. The Geba does have the cast impeller and the Hepu stamped. I just installed one of each not long ago.
'97 B4: 453,000 miles Malone 3, PP520's, Stage 2 cam, SBC3, ARP studs, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR.
BUG*PWR 2013 Award Winner
Old October 29th, 2018, 05:52   #6
Mongler98
every stamped impeller i have ever used, i always have put a small tack weld on it, never had any issues.
Old October 29th, 2018, 10:42   #7
clyde
That's a good idea! Are the impellers stainless?
Old October 29th, 2018, 17:17   #8
Mongler98
not that ive noticed, if it is, its defiantly not 304. it welds like any other steel sheet metal thats been galvanized. i have never noticed a burn off of the galvanized metal though or rusting on the welds as the pumps i do it to all live in a healthy antifreeze mix of whatever the car it goes into needs.
If i had to guess, its a cheep stainless plating thats on it. If i remember to, i will leave one that i take off and let it sit outside for a bit and see if it rusts.
I can say that the tack weld i do is very small, i basically just put 2 pencil eraser sized spot welds on it and file it flush and let the penetration of the weld do the work.
Old October 29th, 2018, 18:10   #9
Abacus
That helpful B4 guy
Abacus's Avatar
Not really since it'll throw off the impeller being balanced.
Old October 29th, 2018, 18:42   #10
clyde
Of course you're right, Abacus, the rotating mass will change the balance of the rotating parts.
It's a crapshoot, though, whether the direction of change would be negative or positive. The rotating mass is probably not very close to being balanced to begin with…
The two tiny spots of weld are so close to the center of rotation and the mass of those welds is insignificant compared to mass of the hub and the pulley. Would the tiny change even be noticeable without using very sensitive scientific instruments?
Old October 29th, 2018, 20:01   #11
Abacus
That helpful B4 guy
Abacus's Avatar
Give it a try and let us know how it goes.
Old October 29th, 2018, 20:56   #12
KLXD
I've never noticed any balancing holes or grind marks on a water pump impeller.
Current: ’02 Jetta, Auto; ’98 Jetta, 5 Spd; ’98 Dodge, 5 Spd, SB, 4x4; ’84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): ’85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: ’85 Mitsubishi PU, 4D55T; ’81 Rabbit, 1.6; ’80 Dasher, 1.5; ’79 Rabbit, 1.5
Old October 31st, 2018, 05:36   #13
Mongler98
TOP KEK
these pumps spin (depending on the car) at about 1/4 the speed of the crank RPM. Balance this small make NO difference as long as that difference is within say (15 grams) i have no clue as to how much but you get the point.
the cast ones might be balanced enough from casting marks ect but never have i ever seen any marks to indicate that the pump was balanced at all.
Granted i have not done a water pump on every make and model car out there so i can only speak on what i have worked on. I can also say that the only reason i did the welding thing was when it was clearly a slip fit, i have seen pumps come in with the impeller being metal but where it connects to the shaft there is a seam where it slips over as in, NOT a press fit but rater a glue fit. I have seen this on mostly Chevy and GM sh!t boxes.
Maybe it the balancing issue is why so many fail?
All i know is that i have never had a failure of a impeller coming off on these and i cant report any higher than normal failure rate.
Old October 31st, 2018, 07:36   #14
garciapiano
I bought my water pump kit from ECS and it came with a GEBA pump. For what it’s worth, I say don’t sweat the pump - sweat the gasket that seals it to the pump housing. The rubber/metal gasket is what you want. Throw out the flimsy paper one that comes with the pump.
garciapiano is offline   Reply With Quote
Old October 31st, 2018, 07:55   #15
KLXD
I replaced the pump on my '98 for the first time with the last timing belt. Well over 300k.
Really hurt to toss the perfectly good original plastic (I think) pump for a crappy looking cast. Looked like it had 2/3 the flow path of the original.
When to replace water pump and fuel pump? halfbytecode TDI 101 25 December 23rd, 2017 09:08
water vs plastic water pump video leicaman TDI 101 56 July 15th, 2016 10:44
Water Pump/Timing Pump replacement... manoj77@icloud.com VW MKIV-A4 TDIs (VE and PD) 32 August 20th, 2015 09:05
water pump greenskeeper TDI 101 0 April 29th, 2013 13:28
Stretch Bolts for water pump/ water pump change. Vinyl_Addict TDI 101 7 July 11th, 2006 08:11
Page generated in 0.19153 seconds with 11 queries
[Output: 127.08 Kb. compressed to 106.03 Kb. by saving 21.05 Kb. (16.57%)]
