Old October 31st, 2018, 18:33   #16
Vince Waldon
Vince Waldon's Avatar
Jeebus, there's no "polarity" to an incandescent light .
The bulb socket in its plastic housing doesn't care, the filament doesn't care, the electrons could not care less which terminal they flow into or out of, and the engineers that designed it in the early 90s (actually more like the 70's or 80's) were not worried about it either.
Nor did they have future vision that several decades later there's be a mad rush to jam LEDs in there.
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is offline   Reply With Quote
Old November 1st, 2018, 16:36   #17
GoFaster
Moderator at Large
True, but by convention, the easily touched with a finger outer shell of the socket is ground/common, and the harder to touch, buried inside center pin is switched hot/positive.
It doesn't matter so much for 12 volt circuits (which don't present much of a shock hazard), but it matters a lot for 120v AC circuits which represent a more significant shock hazard. The easily touched outer shell is on the "common" (which is grounded at the distribution panel thus not presenting a shock hazard), the hot inner pin is more protected.
That carried over to 12 volt circuits by convention.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old November 1st, 2018, 17:01   #18
Chris_TDI_98
Fuel Economy: 35 mpg with leaking injection pump
I called my local VW dealer, service manager.
He said, Heck no, no reverse polarity, that would be nuts, the outer shell contacts of the rear end bulbs should be negative ground, just like the rest of the car. He then admitted that multiple standards exist for example he tried replacing bulbs in his VW and got the bad luck of a slightly different bulb number which reversed the position of high beam and low beam contacts on the base of dual filament bulbs, so he ordered another set from a different manufacturer and they worked. But obviously he was referring to filaments which are unaffected by reverse polarity.
Chris_TDI_98 is offline   Reply With Quote
Old November 2nd, 2018, 14:40   #19
Digital Corpus
Digital Corpus's Avatar
No need for cutting and splicing. Just swap the pins in the terminal that are providing power…
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old November 4th, 2018, 07:35   #20
Chris_TDI_98
I suspect, and will verify today, that the Mexico VW mk3 factory assembly line tech who originally connected the tail light trunk wiring harness to the fuse relay panel on this car, he/she connected these power wires in reverse polarity, yet the reverse polarity mistake went undetected because the filament tail lights still powered on OK while running reverse polarity!
In my opinion this is the simplest and therefore most plausible explanation for this wiring error which has gone undetected until now.
Except for the presence of excessive RF noise on the battery power lines both while the car is off and while it’s running, which are supposed to be 100% clean DC battety power.
Old November 4th, 2018, 07:43   #21
ToddA1
Fuel Economy: Dismal
Dude, stop overthinking and over complicating things. Swap the wires and be done with it.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old November 4th, 2018, 07:48   #22
Chris_TDI_98
Thumbs up
Of course. Ill swap the wires one time on the fuse panel and keep the right wire color code vs 4x on the rear wiring plugs and mess up the wire color code.
Old November 4th, 2018, 14:24   #23
RoseBud68
Originally Posted by todda1 View Post
dude, stop overthinking and over complicating things. Swap the wires and be done with it.
-todd
lol....
1999 MK3 Jetta TDI 1Z.
RoseBud68 is offline   Reply With Quote
Old November 5th, 2018, 04:47   #24
Mongler98
You are forgetting that this fact is completely dependent on what brand of blinker fluid you use!
Old November 5th, 2018, 13:16   #25
turbodieseldyke
turbodieseldyke's Avatar
TDI(s): 98 jetta
Fuel Economy: 50
Dude
+1. But hey, at least he didn't make this thread a poll.
I personally hate driving behind anyone with LED taillights, at night. Prius and Cadillac are especially bad, almost blindingly bright.
turbodieseldyke is offline   Reply With Quote
Old November 5th, 2018, 15:42   #26
Mongler98
ever get behind an ambulance or firetruck, >9,999 lumens of red light in your face!
Old November 5th, 2018, 18:50   #27
Digital Corpus
It’s because most of those LEDs don’t have an even 360 spread but instead cover a 30 to 60 cone. For practicality, lux is a better unit over lumens.
Old November 7th, 2018, 22:44   #28
turbodieseldyke
TDI(s): 98 jetta
Fuel Economy: 50
Never noticed, as I'm one of those crazy people who pulls over to the right, waits for them to pass, and follows behind a couple hundred feet back.
Old November 8th, 2018, 04:37   #29
Mongler98
NO, not the siren lights and what not, there are plenty of times an ambulance and or fire truck is not in an emergency to get somewhere (usualy back to base), you don't get over unless the sirens are going.
I love about 7 miles from a hospital and its very common to be behind one. those tail lights are like the arc of the covenant bright, my face feels like its melting!
No reverse lights brownnugen VW MKIII-A3/B4 TDIs 8 October 27th, 2016 15:27
No reverse lights Herm TDI VW MKIV-A4 TDIs (VE and PD) 15 December 5th, 2013 07:59
Reverse Lights desgre90 VW MKVI-A6 Jetta Sedan (~ 2011+) 8 March 28th, 2013 18:39
Reverse Lights wildkitty Ontario 13 September 22nd, 2008 06:34
No Reverse Lights Help! jblythe TDI 101 4 December 3rd, 2006 20:15
Page generated in 0.15942 seconds with 11 queries
[Output: 124.95 Kb. compressed to 105.26 Kb. by saving 19.69 Kb. (15.76%)]
