Old October 22nd, 2018, 17:07   #1
Chris_TDI_98
Fuel Economy: 35 mpg with leaking injection pump
Question Reverse lights... Reverse polarity?! ***
Quick question for you experiences with the wiring diagram for the rear reverse lights.
Are the rear reverse lights SUPPOSED to be reverse polarity according to the wiring diagram (which I donít have)?!
Center pin NEGATIVE, ground/shell POSITIVE?!
Trying to find out if my previous owner mucked something up and resulted in reversing the polarity of the rear reverse lights??
I want to make it be the NORMAL polarity, unless VW did indeed design the car to have rear reverse lights wired in reverse polarity...!?
Chris_TDI_98 is offline   Reply With Quote
Old October 22nd, 2018, 18:48   #2
ToddA1
Fuel Economy: Dismal
I seriously doubt it. Get a voltmeter to verify.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old October 22nd, 2018, 20:26   #3
Steve Addy
TDI(s): 97 Mk3
The outer cylinder portion of the bulb should never be positive. If it is on your car then someone has mucked it up.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
the magic triangle spins in the peanut and then apex seals come out
Steve Addy is offline   Reply With Quote
Old October 22nd, 2018, 20:43   #4
RabbitGTI
RabbitGTI's Avatar
Fuel Economy: Don't know. I just feed it and drive.
Unplug it at the transmission and use the brake lights as back up lights. That was my solution. you have to mix in a little "back and pray" too.
Rabbit GTI racecar RIP, 84 Rabbit GTI, 88 Golf GL, 97 Passat TDI, 07 Jetta 2.5, 02 Beetle 2.0, 08 Jetta 2.5 with Aisin Box.
RabbitGTI is offline   Reply With Quote
Old October 23rd, 2018, 01:43   #5
Chris_TDI_98
I did. When I made the original post, it was after having verified with the voltmeter. Itís wired with reverse polarity! This explains why todayís new arrival ďreverse light LEDsĒ were failing to light up. Filaments donít mind about polarity, yet most LEDs do mind. (Other LEDs have electronics built in that accept either polarity just as filaments do.)
Will trace this back tmrw to fuse panel if I must and fix it.
Old October 23rd, 2018, 22:31   #6
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
I ran into the same thing. I was too lazy to try to figure out a fix.
Jetta SS is online now   Reply With Quote
Old October 24th, 2018, 07:03   #7
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2019 to end of April 2020
My suggestion would be to trace the wires back as far as possible and see if there is/was a new socket spliced in ! My former 2002 Jetta had brown wires as the ground wire.
All LED interior bulbs. Several VCDS mods. Darker window tint. EVO skid-plate. Malone Stage 2, Malone DSG tune. Winpower Projector headlights. Angel eyes. LED DRL's. 24mm H&R rear sway bar. Phase 1 & Phase 2 done.
Jetta_Pilot is offline   Reply With Quote
Old October 24th, 2018, 09:48   #8
ToddA1
Easier to cut and splice at the light panel, if youíre not particular about it.
Brown or brown with tracer, is standard ground color, from what Iíve seen on my VWs.
-Todd
'97 B4: Stock
Rabbit build
Old October 24th, 2018, 09:56   #9
Chris_TDI_98
One wrinkle in the equation is, I’ve installed an electronic trailer light module in the trunk area by splicing onto the rear left tail light harness. It’s rather simple electronic module which powers the trailer lighting harness based on the state of the three separate rear lights (tail lights, brake lights, and turn signals), deciding logically whether the left or right trailer light should be off (car lights off), low brightness (tail light), high brightness (brake or turn signal). Could it be the cause of reversing the polarity? I doubt it but asking anyway maybe you guys have some insight.
Old October 24th, 2018, 13:00   #10
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
I'd be willing to bet they're all reversed. I did the same as you last year, bought some led's off ebay hoping to have brighter reverse lights. When they didn't work, tested with dvom finding the reverse polarity on the car.
Old October 24th, 2018, 15:04   #11
Chris_TDI_98
Anyone here got VW contacts on LinkedIn ? Can we ask the VW mk3 vehicle electrical system design team Why TF they engineer the reverse lights to run off positive ground ie reverse polarity ?
Old October 24th, 2018, 15:07   #12
ToddA1
My B4V definitely isnít, but maybe Jettas are.
-Todd
'97 B4: Stock
Rabbit build
Old October 26th, 2018, 05:44   #13
Mongler98
NO, defiantly not
I dint know of any car, let alone a light socket that has the outer casing the + or common. EVER
Old October 31st, 2018, 08:41   #14
Jetta SS
Jetta SS's Avatar
TDI(s): '98 Jetta
Fuel Economy: 48
Saw on vortex they go to the connector inside the trunk and cut off the Locking tabs so that the plug can be plugged in backwards. Alternatively they are using a pin extractor to pull the wires out of the plug to reverse them that way.
Old October 31st, 2018, 17:01   #15
ToddA1
Originally Posted by Mongler98 View Post
NO, defiantly not
Interesting, that this has occurred enough times that threads are created, about it.
-Todd
'97 B4: Stock
Rabbit build
No reverse lights brownnugen VW MKIII-A3/B4 TDIs 8 October 27th, 2016 15:27
No reverse lights Herm TDI VW MKIV-A4 TDIs (VE and PD) 15 December 5th, 2013 07:59
Reverse Lights desgre90 VW MKVI-A6 Jetta Sedan (~ 2011+) 8 March 28th, 2013 18:39
Reverse Lights wildkitty Ontario 13 September 22nd, 2008 06:34
No Reverse Lights Help! jblythe TDI 101 4 December 3rd, 2006 20:15
Page generated in 0.17632 seconds with 11 queries
[Output: 126.24 Kb. compressed to 105.35 Kb. by saving 20.88 Kb. (16.54%)]
