Old November 12th, 2018, 12:07   #91
Steve Addy
TDI(s): 97 Mk3
Congrats! Glad you finally got it figured out.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
the magic triangle spins in the peanut and then apex seals come out
Steve Addy is offline   Reply With Quote
Old November 13th, 2018, 08:19   #92
eddieleephd
Fuel Economy: 38mix / 47@70-75
So in the end it was the crank gear preventing it from starting and the IP could have lived many more happy years with a lift pump beings it was only the lift mechanism that was weak. However, it's probably happy to have been rebuilt.
Glad you got it sorted, not used to the video progress reports. Links tend to disappear, can you import video in the upload manager? Import all from address works well for pictures.
'02 1.8t Jetta Wagon Alh w/5spd swap, SB 21#SM DD, bew lift pump, 11mm IP, VNT17, Malone stage4 tune, Stealth pipe, BMW Cyclonic CCV filter, 2.5"cat back st. pipe,Vr6 brakes, 2" lift, Panzer, Bilstein HD, fill tube ectomy, soon to be Wuzetem p.520 PD_fuel_delivery TDI Search Plug release tool Howto terminal release tools VW/Audi
eddieleephd is offline   Reply With Quote
Old November 13th, 2018, 12:15   #93
Chris_TDI_98
Fuel Economy: 35 mpg with leaking injection pump
Good work Russell. Glad the FEBI crank gear from eEurioParts got your TDI starting again! TDIclub community is great!
Chris_TDI_98 is offline   Reply With Quote
Old November 27th, 2018, 06:23   #94
Dieselworld
Fuel Economy: 55 mpg Hwy
The whole pump was rebuilt but the builder said the lift mechanism was what was bad. The vids are from my YT channel so not sure how to do them without the YT links.
D.O.C.I. Doctor of Compression Ignition
WWW.DieselGiant.com
VW how-to pictorials on the web page!
'98 Jetta Tdi 379k
YouTube Channel: https://www.youtube.com/c/dieselworld
Dieselworld is offline   Reply With Quote
Battery good, connections good, 2007 Super Beetle won't start jcwillow777 TDI 101 3 December 20th, 2017 13:23
Crank but no start Sotam123 VW MKIII-A3/B4 TDIs 4 June 19th, 2014 17:14
Cold Start (-20 degC, -4 degF), Good Battery, Good Alternator, Low Parasitic Draw wai-ho.lo VW MKIV-A4 TDIs (VE and PD) 10 February 2nd, 2014 08:49
Need a good ALH short block with pistons and crank mac10190 Private TDI Items for Sale/Wanted 8 December 18th, 2012 19:13
Good Crank No Start BlackGolfOn17s TDI 101 7 September 16th, 2008 22:25
Page generated in 0.14555 seconds with 11 queries
[Output: 66.36 Kb. compressed to 59.71 Kb. by saving 6.65 Kb. (10.02%)]
