Hasenwerk
Vendor , w/Business number
- Joined
- Nov 28, 2003
- Location
- Quesnel, BC
- TDI
- 1982 Cabriolet (BEW|VNT17|Stage4), 1989 VW TriStar Syncro soon-to-be CR TDI (CBEA), 2001 Ford Ranger Edge 4x4 (ALH|VNT17|R520|Stage4)
OK - after several weeks of prep work I am ready to begin the swap with what I feel is almost a dead end question. But first some back ground.
Recipient Vehicle:
1986 Volkswagen Cabriolet that belongs to my 17 year old daughter Loraine. Nice rust free Texas car
Donor engine:
2005 Jetta TDI - engine code BEW
Over the past few winters I have been missing around with it in what very little spare time I had. It was going to be a 1.8L K04 "AEB" gasser, when my daughter asked if it would have as much performance as her bothers ALH TDI. Then she asked about fuel economy and the decision was made to go to Diesel power! Out came the mounted 1.8T and now the Diesel engine sits in front of the Cabriolet.
The car was one of those interesting American models with AC and no PS. The AC system has been removed as why do you need AC in a convertible!?
We had a cable clutch system on the 02J transmission that was attached to the 1.8T but it was SO hard to push the high performance clutch without busting out my knee. I have spent the last few weeks fitting a Jetta MK3 brake and clutch pedal assembly, brake booster and master cylinder along with the MK3 slave cylinder to activate the 02J clutch. The 10.1" Jetta brakes are also being installed. MK4 accelerator pedal is in the mix as everything was too narrow for the MK3 pedal.
MK3 Pedals
MK3 booster, master cylinder and clutch cylinder.
The ceramic fuse electrical system has been removed and in it's place will be a Central Electric 2 system.
I've been spending the last few days working on the mounts. I purchased a few years ago some 02J > MK1 mounts and fitting the front mount and engine mount to the 1.8T was no issue other than some plastic manipulation.
The issue I am having now is the differences in the new style block that the BEW uses. I have seen several swaps where some cutting and pasting to the MK1 mount and voila it fits the ALH, so how hard could it be to do the same to the BEW....
Uh oh!
Something is really telling me that I can't get there from here as the "ears" that go to the frame of the car will hit the timing belt. Has anyone succesfully used MK1 mounts on a BEW? Or does it look like I have to break out the TIG and install a MK4 mount system on the cabriolet? Also, would I be able to get away with the MK4 passenger mount and leave everything else as is? Or should I say screw it and install an ALH engine in here and wimp out and do this the simpler way?
Recipient Vehicle:
Donor engine:
MK3 Pedals
Uh oh!
