msalyers
If I do a auto to 5 speed swap which is easier swapping the ecu and all or rewiring I have a complete donor car does the 5 speed have a tcu if so will they interchange
Just follow the 5speed swap instructions. The wiring READS more complicated than it is to actually do. No tcu in a manual and no need to swap ecu's.If I do a auto to 5 speed swap which is easier swapping the ecu and all or rewiring I have a complete donor car does the 5 speed have a tcu if so will they interchange
Buy the cable, and a laptop, if you don't have one.Can't I just switch to the standard Ecu out of the donor car I don't have access to vagcom
You will open a whole new can of worms trying to switch ECU's.Can't I just switch to the standard Ecu out of the donor car I don't have access to vagcom
