jackjtr
Hi All,
I'm new to the forum and wanted to get some opinions on power upgrades. I'm swapping a 1Z from a 97 B4 Passat into my 2002 EuroVan. I was comfortable with the 201hp and 181ft lbs the 24v VR was putting through the automatic and it was more than plenty.
The upgrades I am considering so far are:
-K03/K04 Hybrid Turbo
-PD150 Intake
-P&P Head
-Agressive Cam (most likey from Kerma)
-Head Studs
-New Crank Sprocket (not a power upgrade per se, but known to fail)
-Bigger Injectors
I don't have a power goal, but I'd like to make the van driveable. I hear ALH pistons are beefier than the 1Zs. Would that be best for my setup? I'd like to avoid touching the bottom end at all costs as the engine seems relatively healthy as-is and only has 174k miles on it. An 11mm pump may also be in my future. All of these upgrades may come later after the engine is already installed, but I'd like to be set up for them.
The Passat weighs ~3000lbs. The EuroVan weighs ~4500lbs.
In a nutshell, I'm looking for a semi-powerful setup with as little stress on the engine as possible. I am willing to sacrifice a lot of power for long term reliability gains. (I.E. Not pulled over on the highway with smoke billowing out of the hood and a hole through a piston)
(Apologies for my basic TDI knowledge. New to diesels.)
-PD150 Intake
-P&P Head
-Head Studs
-Bigger Injectors
