Johnny
- Joined
- Nov 19, 2000
- Location
- Brampton, Ontario, Canada
- TDI
- 2005 Passat, TDI Wagon, in Silver Blue Metalic
This problem started last summer and I have been frustrated with it since. My car was working fine, then one hot day with the air conditioning on I noticed very sluggish performance while trying to accelerate. I always noticed this with the "air" on but this was worse. After turning the air off the performance did not improve to where it was before. I have tried advancing and retarding the timming, unplugging the wastegate pressure hose from the N75, so the wastegate stays closed. None of these things made any improvement at all! I hooked up VW tools and got an arror code of MAP (manifold absolute pressure out of range) intermittent. Plus the standard glow plug monitoring intermittant. But that was last summer, nothing since. The black line from the boost feed to the intake, to the ECU, is not blocked or leaking. Here's the odd thing, the power is fine once I get up to speed. I can accelerate fine on the highway and I have no top end performance issues, it's just getting there that I'm having trouble. In 1st, 2nd, and 3rd, the power doesn't come on untill I reach 2,100 RPM and then it comes on nicely all the way up. My worst situation is trying to accelerate from a stop, up hill, with four adults in the car. Any ideas? Thanks guys!
