Old February 11th, 2004, 04:51   #1
USdan
Default headlight bulb changing?
When it rains, it pours. My left or driver side low beam went on my '96 Passat. Luckily there was a recent thread on the various ways to change it.
It is still raining.
On my '99 NB the left low beam went on that as well.
Here is where I need advice.
Is the change done by , remove the front Left wheel, remove the wheel well liner, to get to the bulb?
USdan is offline   Reply With Quote
Old February 11th, 2004, 06:28   #2
dnk
the new beetle headlight assembly will come out of the fender from the front. there is a release mechanism at the rear of the headlight assembly - open the hood and look at the back of the headlight. there should be a hook-shaped lever near the end of the headlight closest to the passenger compartment. at the base of this hook (the part where it connects to the headlight) there's a little release button. it's grey plastic and has an X molded into it on my car. you press down the release, and start turning the hook-shaped handle. it'll probably be pretty sticky, so you'll have to alternate moving the hook a bit, and pulling on the headlight lens from the outside of the fender.
take it easy on the hook - it's fairly easy to break. move it a little, pull a little, swear a little, repeat. it'll eventually come all the way out. once you have the headlight assembly loose, the harness will unplug from the back of the headlamp assembly, and then you can take it over to the bench to replace the lamp.
there's a single screw that holds the rear panel on the headlight - once it's off you can unplug the wire from the lamp, release the locking wire, and replace the lamp. you probably know this, but i'll mention that shouldn't touch the glass part of the lamp. check the wiring over while you're in there - it tends to overheat and burn on my car. repair as required.
before you put the headlight assembly back in the fender, take some time to clean the rails and sliders, and spray them with silicone spray. that will make them easier to put back in, and easier to take out next time.
good luck! let us know how it turns out.
m.
dnk is offline   Reply With Quote
Old February 12th, 2004, 04:33   #3
USdan
Thanks a bunch! Its a releif to know I don't have to jack the car up and remove a wheel for a bulb change.
I went to one Wally World last night for a bulb. The only one for the NB was an opened package. NOT!
I was also after the 9006 for the Passat. None availible!
No Cool Blue, No Long Life, no Nuclear Radiation Burn!
I'll check out my other Wally World for my bulb needs.
K-mart wanted $14.95 for the 9006.
Is that part of George W. economic expolsion?
One-eyed
Page generated in 0.13561 seconds with 10 queries
[Output: 53.30 Kb. compressed to 48.27 Kb. by saving 5.03 Kb. (9.44%)]
