Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old January 4th, 2020, 13:39   #1
benTspanner
Default 2007 BMN Diagnosis thoughts Boost, Intake or EGR?
So,
I recently got a P0401 Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected.
Stripped and cleaned the EGR but mil light returned on test drive. When I cleared the fault when warm, mil light did not return during several hours of driving until cold start. Then back on.
Cleared the fault again. Did not return
When on the test drive I was on the motorway during heavy rain with cruise control in and hit a patch of standing water which caused the ESP to kick in, cut out the cruise control and drop revs - it did it's job.
Immediately after, MIL light came on and car went into limp mode.
Limp worked for a while - going up hill with some weight in the boot - but then slowly died off, started to cough a bit and finally stalled out on an ext ramp up hill. During this time the DPF load coefficient started to climb quite quickly (ie pressure differential over the DPF) and was up to 54% by the time it stalled out.
The engine would then not restart.
Fault code P0299 - Boost Pressure Regulation: Control Range Not Reached was now logged on VCDS.
So far all I have been able to do is use a vacuum pump to check the turbo vane actuator which appears to be moving freely.
Anybody got any thoughts as to what may have caused the death here? Any ideas on further diagnosis with an engine that will not start?
Thanks in advance
Ben
benTspanner is offline   Reply With Quote
Old January 4th, 2020, 13:42   #2
benTspanner
Sorry Wrong forum I think, I have posted in the mk4 forum instead
Post Gelled Up Thoughts/Diagnosis help wanted TDI Convert TDI 101 4 February 5th, 2013 11:35
Need thoughts on possible boost leak - low boost, no power, etc... chaloux VW MKIV-A4 TDIs (VE and PD) 5 March 23rd, 2011 13:07
Boost hose going to EGR/intake manifold... slpopp VW MKIV-A4 TDIs (VE and PD) 20 March 2nd, 2011 10:17
Boost Spike and Diagnosis dataiv VW MKIV-A4 TDIs (VE and PD) 34 January 5th, 2007 11:14
EGR / Intake Ckeaning (thoughts and problems) k1rod VW MKIV-A4 TDIs (VE and PD) 10 April 27th, 2005 10:00
Page generated in 0.13882 seconds with 11 queries
[Output: 52.42 Kb. compressed to 48.53 Kb. by saving 3.89 Kb. (7.42%)]
