Old April 5th, 2019, 14:50   #1
thundershorts
Default master brake cylinder failing
2015 sel tdi 31k
When starting in morning after sitting overnight vacuum leak causes brake pedal to be hard, some effort required to close safety switch to engage start, after start, pedal will bleed down close to floor in 30 seconds. At stops it bleeds down at about same rate. Dealer states this is normal for diesels, although my 60k 2013 tdi sel showed none of these symptoms. Except for the source of vacuum, pump vs manifold, I would doubt that Passat gasser has a different master vac/master cyl than the tdi version. My experience is that the m/c is leaking internally as no fluid appears in the master vac or any other place and fluid level remains at same level. It would fail Pa inspection. I just want to get it replaced before the warranty is up in 4k miles so I don't get boned. Any one else experience this?
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old April 5th, 2019, 15:27   #2
tdiatlast
A quick advanced search found this...
http://forums.tdiclub.com/showthread...ff+brake+pedal
There are other threads discussing your symptoms.
2014 Passat TDI, 2009 JSW TDI DSG (buyback)
2015 Nissan LeafS ($.02/mile fuel cost)
2014 Toyota Avalon Hybrid Limited (39.5mpg C/H)
2013 Ford CMax Hybrid (39.2mpg C/H)
2017 Ford Energi Titanium, purchased 12/15/18
tdiatlast is offline   Reply With Quote
Old April 8th, 2019, 15:32   #3
thundershorts
part number for passat m/c tdi has been superceded to a new number. Mine is getting changed next monday. we'll see if they fix the vacuum leak as well.
Old April 9th, 2019, 05:07   #4
roni024
Will you please post the new part number when you receive your invoice?
roni024 is offline   Reply With Quote
Old April 10th, 2019, 04:32   #5
thundershorts
I most certainly will post the new part# as soon as I have it. I might just get it today and post.
Old April 10th, 2019, 07:05   #6
thundershorts
new master cyl part# for 2015 passat tdi: 1K1614019AG
Vacuum check valve booster/tubing assembly is currently back ordered.
Old April 17th, 2019, 14:42   #7
thundershorts
M/c replaced, no more pedal bleed down but vacuum check valve for booster still bo.
Old April 18th, 2019, 04:39   #8
roni024
thundershorts: Thank you for your continual updates. What's "bo" mean?
Old April 18th, 2019, 11:46   #9
740GLE
Does the pedal go to the floor at red lights? to me that would be the nail in the coffin a new MC was needed.
vacuum leaks are tricky to track down.
Hers: 2015 Passat SEL (NOS) w/ VW fix and Malone Stage 2 (low torque for DMF shudder).
Old April 18th, 2019, 16:52   #10
thundershorts
bo=back order, sorry. the check valve for the master vac most likely would account for the vacuum leak overnight and they are still on bo.
Old April 19th, 2019, 05:59   #11
roni024
Doh! I should've inferred that from your previous post...
Brake Master Cylinder Squibals TDI 101 4 December 8th, 2016 13:45
Brake master cylinder/clutch master cylinder? dweisel VW MKIII-A3/B4 TDIs 16 July 2nd, 2015 19:09
Replaced my Brake Master Cylinder - Now Brake Problems!!!! HELP copatdir6 TDI 101 13 October 11th, 2013 13:44
Brake Master Cylinder piers VW MKIV-A4 TDIs (VE and PD) 1 February 23rd, 2007 10:28
master cylinder - how tell if failing BathTDI TDI 101 1 May 3rd, 2004 08:37
Page generated in 0.14442 seconds with 11 queries
[Output: 97.97 Kb. compressed to 82.47 Kb. by saving 15.51 Kb. (15.83%)]
