Old June 9th, 2015, 09:57   #1
VWdrummer
Fuel Economy: 40-41 measured with Fuelly
Default LED Bulb Error GP light without using Resistors!!! FOR MK4 ONLY
I have a 2002 Jetta TDI Wagon that I put LED tail lights in. I got the flashing Glow Plug and hopped on here looking for a solution to my problem. I found how to fix the hyper-flash issue by cutting a trace in the relay as well. My car is tuned by KERMA TDI and I sent an email to the tuner and he tuned out tail light bulb out error so that the car cannot see that error code ever again. Apparently this is only an issue for the MK4 cars because they are non can-bus and resistance monitored. I hated the idea of using load resistors because they get very hot and still use the same power as a regular bulb.
I had to edit this post because of rude people sending messages and posts with misinformation about what I have done to my car.
2002 Jetta: Bosio DLC 1019 nozzles, 4 speed auto to (DRW) 6-speed manual conversion, 20th-anniversary GTI big brake kit, BW S7 turbo (Kerma), Darkside Developments Intake Manifold, APR FMIC, KERMA TDI tune, 3" Turbo back exhaust
VWdrummer is offline   Reply With Quote
Old June 9th, 2015, 13:24   #2
JDSwan87
Black Swamp Thing
JDSwan87's Avatar
I thought the LED bulbs from DeAutoKey had resistors built into the bulbs?
Stella (Mine now): 2005 Shadow Blue Jetta Wagon TDI 09A
Mods: RC1. VCDS HEX-CAN USB (near Toledo, OH)
JDSwan87 is offline   Reply With Quote
Old June 16th, 2015, 09:41   #3
VWdrummer
True, but my goal was to get these bulbs to work without wasting any power. Some LED bulbs I had before had resistors that got so hot that they melted my tail light housings.
LED head light bulb replacment? 1986.5supra_kid VW MKIII-A3/B4 TDIs 5 February 11th, 2017 10:46
LED parking light install and error... akrievins VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 July 11th, 2014 09:55
Bulb out error light after led tails install help! NIN846 OBD Scanners 1 January 29th, 2012 15:00
Flashing GP light + P1247 error grtn316 TDI 101 4 August 17th, 2008 05:08
LED taillights causing flashing GP light cdfurst TDI 101 12 December 19th, 2007 04:22
Page generated in 0.12675 seconds with 11 queries
[Output: 60.76 Kb. compressed to 55.12 Kb. by saving 5.63 Kb. (9.27%)]
