Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI Fuel Economy
TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed.
Old December 23rd, 2011, 18:06   #1
cristoaca
Default '12 Passat vs '10+Golf/Jetta mpg
Could somebody please explain why is the new Passat TDI getting better fuel economy (according to the owners who posted in "Real World MPG thread" from Passat specific discussion area) than the TDI's Golf or Jetta?
Thank you.
cristoaca is offline   Reply With Quote
Old December 23rd, 2011, 18:38   #2
leicaman
leicaman's Avatar
Fuel Economy: Much better than the average car... :o)
The reason is mainly due to the slightly different emissions system, namely that of Ad-Blue agent that you will need to add at regular intervals. Right now only the Passat has that. The other cars can go without it as the cars are lighter,even though the engine is essentially the same. The '12 has some extra tweaks that make them a little more efficient.
2015 Golf SE TDI with DSG, 88k.
and formerly a 2005 Passat GLS TDI - RIP, 208k miles. Many good memories and friends made with this car.
leicaman is offline   Reply With Quote
Old December 23rd, 2011, 19:22   #3
cristoaca
Thank you.
Old December 28th, 2011, 08:51   #4
psd1
Fuel Economy: See Fuelly link
So, even though the numbers look better on paper, the cost of the AD Blue must be factored in to the overall operating cost of the vehicle.
psd1 is offline   Reply With Quote
Old December 28th, 2011, 12:55   #5
MikeMars
I think its cheaper than a new DPF
Audi A2 TDi 1.4*, 6M/0.588, mild aero mods, 103hp remap (* 3 pot version of 1.9PD)
Y2000 Passat TDi 115 PD RETIRED, M5, Best 75MPGuk, usually 60-70. 900m clubx7. 1000 mile clubx3.
VW Fuel saving tips
MikeMars is offline   Reply With Quote
Old January 3rd, 2012, 10:24   #6
Manyvws
Thumbs up 2012 Passat factory tuning
Thank you.
Hope this helps
The 2012 Passat's mapping is different than the Jetta's and is enabled do to the Urea injection which lowers NOx gases so,,,,,The passat has more power as it is sort off (chipped) from the factory. VW is being conservative about HP and Torque on this model. Urea tank full lasts about 10,000 miles. Costs around $12.00
I have a 2012 Passat TDI SE with the 6 spd std and just finish a ride from Boston to Portland Maine on sunday. About 107 miles, 90% interstate, 4 adults, 70 mph, straight pump diesel and got 46.4 MPG! This car will easily get 50s plus when broken-in.
Manyvws is offline   Reply With Quote
Old January 3rd, 2012, 12:35   #7
GoFaster
Moderator at Large
For what must be the BAZILLIONTH time on these forms ...
The need for a DPF (controls soot) is independent of the need for AdBlue or other methods of NOx control!
ALL 2007 and later model year diesel engines in on-road vehicles use a DPF.
EVERY.
SINGLE.
ONE.
Inclluding every single one that uses AdBlue. Including every single one that does not. Including every single VW Passat TDI. Including every single Mercedes, BMW, VW, Ford, Dodge, GM, and all sorts of heavier-duty trucks.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old January 3rd, 2012, 12:36   #8
GoFaster
Moderator at Large
It's true, but the apparent improvement in fuel consumption reduces fuel cost by a fair bit more than what it's going to cost to occasionally refill the AdBlue tank.
Brian P.
Old January 3rd, 2012, 13:34   #9
psd1
True, but MPG is only one facet in factoring the cost to operate a vehicle. It's easy for folks to forget that the the urea system is there (another thing to go wrong) and that cost of the fluid itself.
Old January 4th, 2012, 04:40   #10
MikeMars
Interesting, thanks. (Although for TDIs I'm seeing the year 2009 mentioned elsewhere).
VW Fuel saving tips
Old January 4th, 2012, 04:54   #11
GotEuroCorrado
My 2006 v10 and my mothers both have dpf...
Sent from my SGH-T989 using Tapatalk
ACS TDI SPECIFIC MAINTENANCE AND REPAIR IN HATBORO PA (267)317-8229
$650+/- ALH/BEW/BRM/BHW/CBEA/CJAA TIMING BELT KIT INSTALLED NEAR PHILADELPHIA !
used parts FS: http://tinyurl.com/zfdjgyh
smoking deals on TIMING BELT KITS: http://tinyurl.com/ov57jfl
GotEuroCorrado is offline   Reply With Quote
Old January 4th, 2012, 13:05   #12
VWBeamer
Fuel Economy: 42.79 mpg Woot!
Thanks, it bugs me also. ....but is the urea cheaper than a new HPFP?
EVERY.
SINGLE.
ONE.
800 club. 828.5 miles, 16.33 gallons, 50.79 mpg.
2004 Jetta GLS Wagon TDi-17/22, 2.5 DP.2.5 Exhaust, Stage 5 Malone Tune.3 bar MAP, pd150 Injectors, Ebay FMIC, 1.8T Pancake pipe. Gutted PD100 intake.
VWBeamer is offline   Reply With Quote
Old January 4th, 2012, 13:13   #13
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Thumbs down
Threads turn into HPFP crap quickly enough without this blatant trolling. While it's funny, some idiot will undoubtedly take the bait even if it wasn't intended as bait.
Old January 4th, 2012, 14:27   #14
VWBeamer
Sorry, just joking....half way trolling just because the HPFP sky is falling folks are so much fun!!
Old January 5th, 2012, 09:18   #15
NHTDI
Fuel Economy: 38/42
I think the Passat (6M) has different gear ratio's. IIRC a Passat owner stated 2000 rpm at 70mph. That's 300 rpm lower than my 09 Jetta 6M. Lower rpms could be another factor in the improved mpg.
Can't wait to see what these cars will get once broken in and when summer fuel arrives!
drooling...
14 BMW 328D Xd
11 Ford F350 PSD
09 Jetta Sport wagon
04 Passat GLS TDI
01 Jetta GLS TDI (tradein)
NHTDI is offline   Reply With Quote
30/42 MPG Golf, 31/43 MPG Passat? Polak VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 10 June 19th, 2011 22:29
'10 GOLF TDI, 59.9 MPG, 921 ml/tank range RomanL TDI Fuel Economy 6 January 27th, 2011 08:18
WTB - 6-12 yr old, 5-spd TDI Jetta, 4-dr Golf, or Passat in San Antonio, TX Area unbiker TDI Cars for Sale/Wanted 0 December 29th, 2010 08:41
Frostheater fits 09-10' Jetta & 10' Golf jasonTDI VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 December 23rd, 2009 17:50
10 or 12 mm GP on 96 passat tdi tdjoe VW MKIV-A4 TDIs (VE and PD) 3 October 28th, 2003 06:05
Page generated in 0.15085 seconds with 11 queries
[Output: 128.77 Kb. compressed to 107.60 Kb. by saving 21.17 Kb. (16.44%)]
