Old February 3rd, 2000, 04:43   #1
BUG*PWR
RIP, Gone But Not Forgotten
Default Changing a NB headlight bulb.
First off all the head light bulbs including the fog are H1s.
1. There is a plastic, black lever above the headlight assembly. You need
to slide this up to unlock the assembly.
2. You may have a hard time sliding the lever, if so you will see this
little black button/tab. With a screw driver press it in. The lever will slide much easier
now.
3. Pull the assembly out. If you did the above correctly, dont be afriad
to use a little elbow grease. Dont pull it out to far! There is a black
connector attached the assembly.
4. Remove the black connector. Pull on the back catch tab to release
it.
5. You now have the assembly in your hands. Take the back, black, plastic
cover off. Again relieving the tabs.
6. You are now in the assembly. There are two bulbs. The one closest to
you (not deep in the assembly) is the low beam bulb. The metal retaining
clip that keeps the bulb in place. Push down on the clip and lift it up and over.
You can now carefully pull the bulb out. It will still be attached to a wire with a
black, L shaped piece. PULL THE BLACK PIECE TILL IT DISCONNECTS FROM THE BULB!!
7. Attach your new bulb. Make sure you do NOT touch the bulb. If you do,
clean the bulb with alcohol and dry it off. If you touch the bulb it wont
last long.
8. Reassemble in reverse order. The headlight housing slides in after putting the
connector on. There is a channel for it to slide in so align it into the channel
before sliding in.
9. Twice now the dealer fixed my headlight. Both times the bulb was OK and only a connection problem.
So I sprayer all connectors with Tuner Cleaner to insure better electronic connection.
10. One less reason not to bring it to an incompetent dealer
BUG*PWR is offline   Reply With Quote
Old February 3rd, 2000, 13:23   #2
HowardZ
Default Re: Changing a NB headlight bulb.
Am I to assume that first the wheel and inner fender must be removed?
HowardZ is offline   Reply With Quote
Old February 3rd, 2000, 18:25   #3
BUG*PWR
No no HowardZ, Just follow the procedure. The headlight just slides out of the stationary bucket when the lever is lifted.
Old February 3rd, 2000, 19:23   #4
HowardZ
Where is this lever?
Under the hood?
Old February 4th, 2000, 08:07   #5
HowardZ
Eventually I'll buy a Bentley manual when they cover the 2000 model. Diagrams are such a nice thing.
Old February 4th, 2000, 08:38   #6
BUG*PWR
HowardZ, Your killing me man !
I'm going to make a .pdf and send it to you.
A picture is worth a thousand words and I don't like typing.
Old February 4th, 2000, 08:46   #7
HowardZ
Wow, great diagram.
Thanks a million.
Now I am ready when a bulb burns out.
Page generated in 0.16301 seconds with 10 queries
[Output: 70.99 Kb. compressed to 61.12 Kb. by saving 9.87 Kb. (13.91%)]
