Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Audi A3
Audi A3 Discussions area for Audi A3 TDI (2010+ in Canada & the US).
Old November 15th, 2019, 14:18   #1
paperthin
TDI(s): 15 A3 TDI
Default third Brake light Failing
So on my 2015 A3 TDI the 3rd brake light does not come on. I took it off and bench tested it, it is fine. I am about to go out and double check that 12v is going to the connector but not sure if that is going to work. I will scan with VCDS shortly too. Is there fuse I can check? Any other ideas? Everything else is working properly.
2009 Jetta TDI (bought back), 2015 A3 TDI (current)
paperthin is offline   Reply With Quote
Old November 17th, 2019, 07:36   #2
paperthin
TDI(s): 15 A3 TDI
Scanned and got the following which is no surprise.
11274 - Bulb for Center Brake Light
B12C6 15 [009] - Open or Short to Plus
Other places on the internet suggest loose solder on the light. This is not the case as I benched tested it again, and works perfectly, all diodes on bright.
I cleared all faults and will drive on monday to see what comes back.
I am inclined to just let it go for now. Anyone have schematics?
Old November 25th, 2019, 14:25   #3
paperthin
TDI(s): 15 A3 TDI
Well...i haven't figured out what is wrong. I tried to measure the voltage out of the cable connector but had difficulties. The fault comes on immediately. If I figure out anything else I will update. I was hoping it was a loose solder like many people on the internet suggest. The cheapest I can find the light right now is $150 CAD.
Old November 30th, 2019, 17:58   #4
A3Dave
TDI(s): Audi A3
Connector is good? I had my turn signal connector melt a few days ago.
A3Dave is offline   Reply With Quote
Old December 4th, 2019, 07:22   #5
paperthin
TDI(s): 15 A3 TDI
I will take a closer look when I get a chance and report back, I don't think I looked at it close enough.
master brake cylinder failing thundershorts VW Passat Family (NMS and B7) TDIs (2012+) 10 April 19th, 2019 05:59
headlight, fog light, higbeam consecutively failing... HELP! Melvin253 VW MKIV-A4 TDIs (VE and PD) 0 June 23rd, 2012 19:41
G60 brake upgrade and failing VW97JettaTDI Upgrades (non TDI Engine related) 9 November 24th, 2010 09:53
02 TDI Bright/Lowbeam light switch failing? Maizor TDI 101 2 October 29th, 2010 20:57
turn indicator, brake system and failing seat ltz VW B5 Passat TDIs 6 June 29th, 2006 17:04
Page generated in 0.11821 seconds with 13 queries
[Output: 69.75 Kb. compressed to 61.66 Kb. by saving 8.09 Kb. (11.60%)]
