Pm me!Anybody got a copy of 5382 firmware to share?
If someone touches the screen and moves the view, it drops out of auto-track mode. In the upper right corner of the screen there will be an icon (I think it has arrows pointing in four directions). If you touch this icon, it turns auto-track back on. This is a normal function that allows you to move the screen around and look at areas beyond your current position. I've used it occasionally, and touching the icon always restores tracking.An interesting tale about VW service and the RNS-510. I have a late 2013 Passat TDI SEL (HW: HO2, SW: 3696, Map Ver: 8050) and in general am very happy with the vehicle. I had resigned myself to the slowness of the RNS-510, but generally found it tolerable. Shortly after a recall to fix an ECO issue and lighting, I noticed that the map in both Navigation and Map modes was not following the vehicle location. In fact, the only way to show the vehicle on the map was to zoom way out, manually recenter the vehicle indicator using the touch screen and then zoom back into a useable scale, this combined with periodic random reboots as I was driving convinced me that the unit was either dying or really screwed up. So off to my VW dealer, after 5 days, I'm told that they have "talked to VW help line" and are assured that this is "normal behavior" for an RSN-510. Well it certainly wasn't for the first 20k+ miles and it also simply isn't acceptable. So I'm soliciting input from members about their experience, is anyone else having similar problems? Is this really "normal behavior" and if so why didn't it evidence itself earlier?
Update the firmware to 4366 and see of that corrects it.An interesting tale about VW service and the RNS-510. I have a late 2013 Passat TDI SEL (HW: HO2, SW: 3696, Map Ver: 8050) and in general am very happy with the vehicle. I had resigned myself to the slowness of the RNS-510, but generally found it tolerable. Shortly after a recall to fix an ECO issue and lighting, I noticed that the map in both Navigation and Map modes was not following the vehicle location. In fact, the only way to show the vehicle on the map was to zoom way out, manually recenter the vehicle indicator using the touch screen and then zoom back into a useable scale, this combined with periodic random reboots as I was driving convinced me that the unit was either dying or really screwed up. So off to my VW dealer, after 5 days, I'm told that they have "talked to VW help line" and are assured that this is "normal behavior" for an RSN-510. Well it certainly wasn't for the first 20k+ miles and it also simply isn't acceptable. So I'm soliciting input from members about their experience, is anyone else having similar problems? Is this really "normal behavior" and if so why didn't it evidence itself earlier?
accokeek:If someone touches the screen and moves the view, it drops out of auto-track mode. In the upper right corner of the screen there will be an icon (I think it has arrows pointing in four directions). If you touch this icon, it turns auto-track back on. This is a normal function that allows you to move the screen around and look at areas beyond your current position. I've used it occasionally, and touching the icon always restores tracking.
Im just new but the VW watercooled forum in Australia has modified firmware for different areas. BUT NOT NORTH AMERICAI just checked the status of my RNS-510 and it's showing the following:
HW Index: H04
SW Index: 0018
SW version: 20101014A
Boot loader: 3.00
HMI XML: KW14/2010 NAR10
Aside from reading through 57 pages of info or visiting a Stealership; would someone mind steering me towards a link or site that will help me upgrade my firmware?
I appreciate it.
Nice update, and happy ending story. Thanks for sharing.Well it turns out that the problem has been resolved thanks to the perseverance of the techs at Waldorf VW, after being blown off by the VW "Help" Line folks. They drove the car, observed the problem and apparently after some head scratching, decided to do a complete reset of the unit. Problem solved!
There is supposed to be an icon on screen in place of the speed limit advisory when the vehicle location is locked and "auto-track" is turned off. No such icon before reset and now there is one (and it works). The speculation is that one of the random reboots put the unit into an "undefined state" and it was confused. I have requested an ISO of the 4366 firmware upgrade from LokiWolf and plan to install it and then update the map database to the latest version. Then I'll go back to enjoying the car and lurking on this list ;-}
As I remember I'm on FW 3696 and I find the map guidance is sometimes hit or miss about restarting. If I shut the car of to fuel it (say 5-10 minutes) it usually will come back on. But if I have it shutoff longer it often times will force me to restart the guidance when I get back in. Not sure why but it is a quirk that I've seen.I tried out the V10 maps on a road trip yesterday and today. There's a road that has been in use for about 4 years now that the older maps never routed me on and it's using it now. It could have been part of the V9 maps though. I did notice that with SW 5382 that when I stop and shut the car that I have to manually restart the map guidance. With the older firmware it would pick up where it left off.
I'm looking too - without knowing how the firmware is loaded and assuming it's a disk, is anyone interested in forwarding a disk via mail, or if you live in the Seattle/Tacoma metro area, meeting up?Also a newbie,
Does anyone know where I can find firmware 4366 for RNS 510? I tried a couple of PM's to LokiWolf, but no luck.
Thanks in advance everyone.
Mine disappear occasionally but they did with 5378 too. Sometimes the station info doesn't display unless I press the channel on the screen or change the channel.Can people who upgrade to sw5382 confirm if your Sirius station graphics disappeared or not?
what is Peter's contact info for the firmware update info. I have been looking and just can not seem to find himNope, but you can buy it from Peter. He's on here and sells it on eBay.
