Now the car has steering and ABS warning lights. It is possible we put too much voltage on the car's electric system due to the bad positive terminal and the booster, does anyone know what damage this can cause?
This is normal after disconnecting the battery. After approximately 1/2 mile of driving the car will have recalibrated itself and extinguished these lights. Mine did this after removing the battery for the DSG service.
Bruce researched and found a VCDS basic setting procedure that we did on his car. When we went through it the second time, it fixed the problem.
He had been driving several days with the steering not providing much assist when the car was not moving or moving very slow.
The ESP light and yellow skidding car were illuminated. The steering wheel light was yellow, and it had the following codes:
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.3 1502
Shop #: WSC 00000 000 00000
3 Faults Found:
02546 - Steering Limit Stop
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Mileage: 9480 km
Temperature: 42.0°C
Voltage: 14.00 V
Voltage: 13.80 V
00778 - Steering Angle Sensor (G85)
014 - Defective - Intermittent
Freeze Frame:
000 - -
Freeze Frame:
These were eliminated the second time we went through this procedure:
http://wiki.ross-tech.com/index.php/VW_Passat_(3C)_Steering_Assist redirected to the GOLF V Steering Assist page.
Bruce had driven about 150 miles, and tried several other methods involving key on, turn, key off, etc. None of them worked.
Ross-Tech and VCDS come through again.
Thanks to
mopower for letting me borrow his VCDS CAN cable.
